Author Topic: Just getting started, need validation  (Read 816 times)
new2wind
« on: February 08, 2009, 04:21:33 PM »
Beginning my experiments designed for 12-16 mph average winds.  I'm drawn to Lenz2 VAWT turbine.  I plan to follow his wing design and figure I can vary RPM by moving wings in/out relative to center axis, at the compromise of torque.
I have come across a PMDC motor, for freezies, with these specs. Glentek, 9.8 amps, 23 in-lbs torque, 180 VDC, 2400 RPM, 25 KVA/kRPM.  Using a calculation I found on this forum, it seems this would be a good generator for 24VDC charging.
I would appreciate any comments.
« Last Edit: February 08, 2009, 04:21:33 PM by (unknown) »
Re: Just getting started, need validation
« Reply #1 on: February 09, 2009, 09:40:23 AM »
Quick math:
  1. VDC / 2400 RPM = 0.075 Volt/RPM
  2. VDC / 0.075 V/RPM = 320 RPM
That's the speed where it just starts charging a 24V battery.
On the other hand, it will start charging a 12V battery at 160 RPM or so.
These speeds are not usually appropriate for a VAWT.  If you really do have 12-16mph average winds where you live, you probably won't have any problems making any windmill work.  Very few of us live in places with so much wind.
« Last Edit: February 09, 2009, 09:40:23 AM by SparWeb »
new2wind
« Reply #2 on: February 11, 2009, 09:26:00 AM »
Steven,
Thanks for your input.  According to the Lentz design, I should expect 112 RPM @ 15 MPH, under a load.  Compared with your calculations, I appear to be in the correct ballpark to get my 12VDC to the batteries pretty regularly.  I may have to gear the the turbine to the motor to bring the motor speed into acceptable levels.  I realize the loss of torque and higher startup speeds.  Always a compromise in physics.
I'm located near South Point on the Big Island of Hawaii.  Lots of sun and wind.  I should be ripe for off-grid living.
Thanks again,
Mike
« Last Edit: February 11, 2009, 09:26:00 AM by new2wind »
