Author Topic: CMS Magnetics?  (Read 1098 times)
fabricator
  • My smoke got out again
CMS Magnetics?
« on: April 05, 2009, 02:13:18 AM »
Does anybody have any experience with CMS in Plano Texas? They have some pretty good prices on magnets.
« Last Edit: April 05, 2009, 02:13:18 AM by (unknown) »
milltech1
Re: CMS Magnetics?
« Reply #1 on: April 05, 2009, 11:19:21 AM »
Hello fabricator,
     I've built 3 genny's so far and bought all of my magnets from them, I've had no problems so far and they do have very good prices.
Eric
« Last Edit: April 05, 2009, 11:19:21 AM by milltech1 »
fabricator
Re: CMS Magnetics?
« Reply #2 on: April 05, 2009, 12:16:24 PM »
Thanks much for the reply, I'm about to pull the trigger on 32 3x1.5x.75 magnets
with a countersunk hole, will the hole with a countersunk bolt negatively affect
the magnetic fields in any way?
« Last Edit: April 05, 2009, 12:16:24 PM by fabricator »
milltech1
Re: CMS Magnetics?
« Reply #3 on: April 05, 2009, 03:31:55 PM »
I'm not sure if the fields will be affected, maybe someone with more knowledge will chime in on that. I have used the ones with holes in them on my first two genny's, much smaller than what you are going to be using,1"x1" ring mags with 3/16"bore, that is what I have flying right now on my 8 1/2' mill, if there is somekind of negative effect I haven't noticed it.
Eric
Those are some beefy magnets, 3"x1.5"x.75", you must be building quite a large genny.
« Last Edit: April 05, 2009, 03:31:55 PM by milltech1 »
fabricator
Re: CMS Magnetics?
« Reply #4 on: April 05, 2009, 03:41:34 PM »
It's the Dan's 17 footer, I have been doing a lot of reading today, it looks like as long as the fasteners are stainless there will be no problem.
« Last Edit: April 05, 2009, 03:41:34 PM by fabricator »
Re: CMS Magnetics?
« Reply #5 on: April 05, 2009, 03:46:00 PM »
Use stainless steel screws.  Or brass.
Do Not use regular steel screws because they will short some of the flux.
« Last Edit: April 05, 2009, 03:46:00 PM by ghurd »
