Author Topic: Load resistor selection question  (Read 983 times)
ZooT
« on: July 05, 2009, 04:14:48 PM »
A while back I posted a thread about bulding a simple shunt regulator for a smallish solar and/or wind dump controller.
I was told by our friend Flux
2N3055 is limited to about 60W per device, with practical heat sinking, but if you choose a suitable series resistor you can dump 240W as the dissipation in the transistor is 25% with half volts across the resistor.
Now for the question:
Is there an example formaula that I could plug values into to determine the proper resistor value to obtain "half volts" across the resistor?
Thanks much in advance for any help given :)
« Last Edit: July 05, 2009, 04:14:48 PM by (unknown) »
Re: Load resistor selection question
« Reply #1 on: July 05, 2009, 04:28:49 PM »
R=V/I
Aren't you looking for Ohm's law?
A few years ago, I discovered for myself that I did not understand this deceptively simple formula.  I learned a lot from "All About Circuits", too.
« Last Edit: July 05, 2009, 04:28:49 PM by SparWeb »
ZooT
« Reply #2 on: July 07, 2009, 10:57:53 PM »
So I've been banging my head against a wall over something "so" simple?
« Last Edit: July 07, 2009, 10:57:53 PM by ZooT »
