Author Topic: 12 Volt Turbine  (Read 1482 times)
micblock
12 Volt Turbine
« on: January 09, 2010, 05:31:07 AM »
On a 12 volt system 6 coils, using 3 Rectifiers what size rectifier should I use. What voltage & amp will a 12v turbine produce at max.
« Last Edit: January 09, 2010, 05:31:07 AM by (unknown) »
tanner0441
Re: 12 Volt Turbine
« Reply #1 on: January 09, 2010, 06:40:27 AM »
Hi
I would assume a 12V alternator will produce something over 12V..... Then your question ends.. The current will be dependant on the developed voltage and the load, also the wire size. Plus how fast it is spinning.
Read other peoples questions on this site, you should answer every thing you have asked. Or you will learn how to word your question so people can help you..
Brian
« Last Edit: January 09, 2010, 06:40:27 AM by tanner0441 »
micblock
Re: 12 Volt Turbine
« Reply #2 on: January 09, 2010, 07:06:33 AM »
My question is mainly about the Rectifiers what Volts & Amp should I use.
« Last Edit: January 09, 2010, 07:06:33 AM by micblock »
Re: 12 Volt Turbine
« Reply #3 on: January 09, 2010, 08:02:14 AM »
The battery will clamp volts to about 15 max but it is not a abd idea to have higher voltage rectifiers so that it will survive if the battery becomes disconnected. The lowest common diode voltage is about 100 and that will just about stand a 12v machine on open circuit. 200 or 400v devices hardly cost more and are sometimes cheaper.
A 6ft machine is not going to produce much over 30A so use 3 of those 35A single phase potted bridges and mount them on a good heat sink.
36MB20 or 36MB40 will do. There are many other number variants for the same thing/
« Last Edit: January 09, 2010, 08:02:14 AM by Flux »
micblock
Re: 12 Volt Turbine
« Reply #4 on: January 09, 2010, 08:38:01 AM »
  Thank You flux, you saved me once more, you are a wealth of information, you answered my question completely. We are ready to build thanks again.
« Last Edit: January 09, 2010, 08:38:01 AM by micblock »
