Author Topic: MX 60 using Xantrex battery temp sensor?  (Read 1758 times)
Bushwhacker
« on: January 26, 2010, 12:12:31 PM »
I am looking for a battery bank temp sensor to compensate for wide temp fluctuations. (-40 to +100 F extremes) I was told about a 'dealer' saying that Xantrex sensors work on an Outback MX 60. Does anyone know of this combination being used? Did it work properly?
Thanks for your time,
BW
« Last Edit: January 26, 2010, 12:12:31 PM by (unknown) »
hayfarmer
Re: MX 60 using Xantrex battery temp sensor?
« Reply #1 on: January 26, 2010, 01:49:58 PM »
I don't know about the xantrex ,but that is a extreme swing.I built a foam box around my gel batteries in a insulated shed to keep them above 40 F in sub freezing temps and don't feel to happy with 40 F .home depot 2 inch foam helped me.
http://www.fieldlines.com/images/scimages/16067/battery_box_non_vented_gel.jpg
« Last Edit: January 26, 2010, 01:49:58 PM by hayfarmer »
« Reply #2 on: January 26, 2010, 02:20:24 PM »
« Last Edit: January 26, 2010, 02:20:24 PM by TomW »
Bushwhacker
« Reply #3 on: January 27, 2010, 10:50:47 AM »
I have full intentions of doing the foam box as well. I forgot all about the foil foam, thanks for the reminder Tom. Is that a magnum inverter Tom? If so how do you like it? I have a 4024 but it's still in the box. I'm using a 1500 watt Xantrex on 12V right now.
I'll see if my dealer will guarantee it works right. He's a really straight up guy.
« Last Edit: January 27, 2010, 10:50:47 AM by Bushwhacker »
hayfarmer
« Reply #4 on: January 27, 2010, 04:21:39 PM »
Hi,magnum 240volt MS4448AE 48 volt. been running great  10 months so far .
« Last Edit: January 27, 2010, 04:21:39 PM by hayfarmer »
Bushwhacker
« Reply #5 on: January 28, 2010, 10:50:57 PM »
NICE! I have it's little brother as I'm only going 24Volt. I hope it works as well as yours... but longer! ;)
« Last Edit: January 28, 2010, 10:50:57 PM by Bushwhacker »
