Author Topic: Battery Charging Question  (Read 1254 times)
watto24
« on: March 07, 2010, 07:23:15 AM »
If a battery reads 12.6 v can it still pull power from a wind turbine or will it just sit there not pulling any amps.
« Last Edit: March 07, 2010, 07:23:15 AM by (unknown) »
Re: Battery Charging Question
« Reply #1 on: March 07, 2010, 07:40:05 AM »
The battery does not pull amps from the turbine.
The turbine forces amps into the battery.
Depends on the wind turbines open voltage at the time.  The turbine's open voltage has to be higher than the battery voltage for amps to flow into the battery.
Sounds like the turbine has the battery mostly full charged, but has not done any charging in the last day or 2.  The battery has gone down to standing voltage, which is about 12.65V when 'full'.
« Last Edit: March 07, 2010, 07:40:05 AM by ghurd »
watto24
« Reply #2 on: March 07, 2010, 08:50:49 AM »
Thanks for the info now i understand , i also did some test and just proved you thory
« Last Edit: March 07, 2010, 08:50:49 AM by watto24 »
