Author Topic: A simple fix for a high efficiency furnace  (Read 293 times)
« on: January 25, 2004, 02:17:21 PM »
My daughter had called and said her high efficiency furnace had quit working...after browsing around on the internet I ran across this posting on a forum 'Thanks a lot, I found the problem there was snow on the inlet of my high efficiency furnace...I cleared it off and it kicked right in....'
http://ths.gardenweb.com/forums/load/hvac/msg1222291231435.html
So I went over and it wasn't snow but frost
The outlet was putting out very moist air, like what most folks would call steam, and as the inlet is only about a foot away at the same height, the outlet had frosted up the inlet! ...same as snow.
  Ah....everything is so much fun if you can keep it simple!  ( :>) Norm
« Last Edit: January 25, 2004, 02:17:21 PM by (unknown) »
RatOmeter
Re: A simple fix for a high efficiency furnace
« Reply #1 on: January 26, 2004, 12:48:36 PM »
Sounds to me like you should add a flue or something to provide better seperation between the inlet and outlet.  Isn't it a little dangerous to burn other than fresh combustion air?
« Last Edit: January 26, 2004, 12:48:36 PM by RatOmeter »
« Reply #2 on: January 29, 2004, 05:28:02 AM »
   Installed by a professional ....yes it does need some kind of seperation...it has been duly noted and he will hear from us. It still gets a large percentage of fresh air just that it gets humid air too. Appreciate your concern. Thanks RatOmeter. Norm
« Last Edit: January 29, 2004, 05:28:02 AM by Norm »
Radomike
« Reply #3 on: February 22, 2004, 12:05:16 AM »
Norm,
  My furnace is similar to yours, the two pipes maybe only 6in. apart.
  However, my exhaust is a foot taller than the intake; the intake has a 180 elbow on top pointing down.
  I've never had any trouble with it.
  These units make so much water; I wonder how pure it is.  A fellow could water a small indoor garden or something.
  Mike
« Last Edit: February 22, 2004, 12:05:16 AM by Radomike »
