Author Topic: Over Unity systems exist in the real world.  (Read 596 times)
finnsawyer
Re: Over Unity systems exist in the real world.
« Reply #33 on: September 20, 2004, 09:46:40 AM »
The idea would be to have some way to open a hole and eliminate the surface tension so the water above the hole would flow out.  Then shut it and let the water build up again.  Not likely I suppose.
« Last Edit: September 20, 2004, 09:46:40 AM by finnsawyer »
jacquesm
« Reply #34 on: September 20, 2004, 10:05:55 AM »
As soon as you eliminate the surface tension the water will flow down.
And if you try to prohibit that you'll have to pull a hard vacuum in order to get the water out and that requires work.
« Last Edit: September 20, 2004, 10:05:55 AM by jacquesm »
