Author Topic: My pictures are to big!  (Read 355 times)
jmk
« on: October 28, 2005, 11:48:23 PM »
  Sory to bug you guys, but how are you makeing your pictures so small? I haven't worked with a computer till last fall when I came acrossed this web sight. I am useing didgetal pictures that take like 1500 pixels. Can this be shrunk to what it takes to upload them? I would lik to show you my wind work on my turbine, but I can't. I would have took alot more pictures if I knew I could have posted them. I have some pictures I would like to share with you. John
« Last Edit: October 28, 2005, 11:48:23 PM by (unknown) »
nanotech
Re: My pictures are to big!
« Reply #1 on: October 28, 2005, 06:43:39 PM »
If you look on your Start Menu, then go to All Programs (if you're using XP), then get into the Accessories submenu.
In there you'll find the program Paint.
Open Paint and load up your pics.  At the top will be a drop-down menu named "Image".  In there you'll find "Stretch/Skew".
Using a percentage of the original, you can stretch (or shrink in your case) the image to any size you want.
Then just "Save as.." to your upload folder.  Don't just do "Save" as the original master file will be overwritten.
« Last Edit: October 28, 2005, 06:43:39 PM by nanotech »
jmk
« Reply #2 on: October 28, 2005, 07:16:39 PM »
Ok. You almost have some of my pictures. I am lost to the derection. It is showeing all of the little part of the picture. how do I show the whole picture ?
« Last Edit: October 28, 2005, 07:16:39 PM by jmk »
« Reply #3 on: October 28, 2005, 08:50:19 PM »
You should be able to set your camera to take small pictures
 The VGA setting on your camera will be 640x480
  The E-Mail setting on your camera should be 320x240
If you have a good Digital Camera, then you should learn some photo editing software to help you control your picures, like: PhotoShop, Corel Draw or as suggested above, the windows paint program.   Good Luck . . .
« Last Edit: October 28, 2005, 08:50:19 PM by wooferhound »
« Reply #4 on: October 28, 2005, 11:06:49 PM »
just set your camera to its lowest setting[mine uses star settings i set it on one star]--pictures will still turn out great.........
« Last Edit: October 28, 2005, 11:06:49 PM by hiker »
mlz
« Reply #5 on: October 29, 2005, 03:22:05 AM »
Jmk, try IrFanView (google it).  This is a handy program that will resize your pictures in one easy step.  It also will allow you to convert between many different formats.
Here's the link:
http://www.irfanview.com/
Hope that helps...
« Last Edit: October 29, 2005, 03:22:05 AM by mlz »
Scotth
« Reply #6 on: October 29, 2005, 09:21:10 AM »
It works!To date all of my picture have been poster size.I just used this software on a couple of experimental photos I downloaded for a diary posting and they came out perfect.Finally.
« Last Edit: October 29, 2005, 09:21:10 AM by Scotth »
Jeff7
« Reply #7 on: October 30, 2005, 08:33:26 AM »
Make sure when you save too, to use JPG. I've seen some people post BMP files here, and those are huge - 3 bytes per pixel.
And for simple drawings (like something done in paintbrush) with very few colors, there's a format called PNG that does an excellent job of compressing that sort of image.
« Last Edit: October 30, 2005, 08:33:26 AM by Jeff7 »
