Author Topic: 10' blade power at 3 different wind speeds  (Read 390 times)
picmacmillan
« on: February 23, 2005, 04:38:41 PM »
below i will use the formula given by hugh to demostrate how much more power can be made by increasing the wind speed....i will use 10' diameter blades, and 10,15, and 20 mph wind speeds.
  .the formula: blade power(in watts=0.15xblade diameter(squared)xwindspeed(cubed)
                                                 (in meters)  (in meters per second)
10 mph example    power in watts =0.15x3.05(squared)x4.5(cubed)
                                 =127.1 watts
15 mph example    power in watts = 0.15x3.05(squared)x6.71(cubed)
                                 =421.4 watts
20 mph example    power in watts = 0.15x3.05(squared)x8.9(cubed)
                                 =983 watts
      CONCLUSION: 10' blade x 10 mph wind =127.1 watts
                  10' blade x 15 mph wind =421.4 watts
                  10' blade x 20 mph wind =983   watts
There is a substantial increase of power created with a 10 mph increase of wind speed.........pickster
« Last Edit: February 23, 2005, 04:38:41 PM by (unknown) »
johnlm
Re: 10' blade power at 3 different wind speeds
« Reply #1 on: February 23, 2005, 11:21:02 AM »
Your right Pic, the power available at higher wind speeds is pretty impressive.  For my tastes, I enjoy watching my smaller 2 to 4 ft diameter units putting out like a banshee in 20 and up mph winds, but when watching my bigger unit in this kind of wind, I usually kinda wish the wind would drop down to 15 mph or so. Thats why I usually set the furling pretty low, to save stress on the hardware. Maybe I just havent made it strong enough.  This reminds me of the post a few days back where the company rated the output of their Hornet model in a 65 mph wind, and showed curves up to 100 mph or something like that. (One had to squint at the graph to see reality in the 5 to 20 mph range)  Sure hope the guy (on a recent post) asking for guidance on the camp trailer need doesn't (mistakenly) get a Hornet thinking he can light it (the camp trailer) up like a city.
John
« Last Edit: February 23, 2005, 11:21:02 AM by johnlm »
finnsawyer
« Reply #2 on: February 27, 2005, 10:23:34 AM »
O. K. Pic, chew on this.  When air flows around a sphere it's speed increases by 50% near the sphere halfway around.  It then drops with distance from the sphere.  Similarly, when air flows around a cylinder it's speed doubles.
« Last Edit: February 27, 2005, 10:23:34 AM by finnsawyer »
« Reply #3 on: February 27, 2005, 12:11:47 PM »
I'm just getting my blades figured out and now you tell me I should add 8 cylinders around them!
« Last Edit: February 27, 2005, 12:11:47 PM by ghurd »
finnsawyer
« Reply #4 on: February 28, 2005, 08:54:33 AM »
No. But maybe you should put your blades around a sphere or a cylinder.  I just thought that since you were so impressed by the cubic wind power function, you might be interested in some other remarkable wind behavior.
« Last Edit: February 28, 2005, 08:54:33 AM by finnsawyer »
pyrocasto
« Reply #5 on: February 28, 2005, 10:02:05 AM »
So then One BIG sphere in front of the genny, would make it do better?
« Last Edit: February 28, 2005, 10:02:05 AM by pyrocasto »
