Author Topic: 1 Screwdriver Broken Already!!!  (Read 610 times)
valterra
« on: December 03, 2006, 06:30:50 PM »
I recently took my broken microwave apart.  Here are some pictures of the transformer.   Holy Cow!  I think the bulk of the microwave's weight lies in this single piece.  It must weigh 10 lbs.
I already broke 1 screwdriver trying to pry it apart.  As you can see in the last picture, it's actually many "slices" of steel welded together.
All I want to do is rescue those coils! Look at all that nicely-wound copper!
Any secerts?  PS.  I don't own a welder.
Picture 1
Picture 2
Picture 3
« Last Edit: December 03, 2006, 06:30:50 PM by (unknown) »
stephent
Re: 1 Screwdriver Broken Already!!!
« Reply #1 on: December 03, 2006, 11:37:43 AM »
No secret, I use a side grinder with a 1/8th" thick cutting blade to cut the welds through...just better check the "windings" before going to much trouble--some are aluminum wire.
« Last Edit: December 03, 2006, 11:37:43 AM by stephent »
dastardlydan
« Reply #2 on: December 03, 2006, 11:39:40 AM »
Valterra
Grind the welds out ,most coil in fransformer
or I should say fransformer are made like the letter E
lots of plates E shape one up and one down,when you
get the first one out then will come apart easy.
Dan
« Last Edit: December 03, 2006, 11:39:40 AM by dastardlydan »
margusten
« Reply #3 on: December 04, 2006, 02:00:35 AM »
I took apart recently broken microwawe too. Transformer looks exactly like Yours.
Only primary for 220V.
I rewind secondary for 50V. I made transformer for powerful battery charger.
I cut this 2000V coil down by a saw.
It wasn't that easy. It was wind very tight.
Made empty holes by pushing and pulling copper wire pieces out.
Finally it's done.
Only bad thing - this transformer needs cooling fan.
BR,
Margus
« Last Edit: December 04, 2006, 02:00:35 AM by margusten »
jimovonz
« Reply #4 on: December 04, 2006, 02:42:07 AM »
I don't cut the welds right through - maybe only 2mm both sides - then tap it with a hammer. I use pre-cut wooden wedges (from hardware store - used to fix door/window frames into the opening) between the primary and secondary windings to force out the primary. I usually take a hammer to the secondary as its not much use (too fine) Whole job should take less than 5 minutes.
« Last Edit: December 04, 2006, 02:42:07 AM by jimovonz »
Nothing40
« Reply #5 on: December 11, 2006, 11:38:49 PM »
I just cut the secondary winding off and use a screwdriver/hammer to tap the rest of the winding out of the holes in the core.
Then rewind as you wish!
Here's a 12V power supply I slapped together..
http://www.users.qwest.net/~ptaylor/Electronics/MOTpowersupply/12Vhighcurrentsupply.jpg
(Yes,it's ugly.)
« Last Edit: December 11, 2006, 11:38:49 PM by Nothing40 »
