Author Topic: Newbie needing pointed in the correct direction [locked]  (Read 1275 times)
dentdoc
« on: February 17, 2008, 02:47:16 PM »
To introduce myself and my nephews into solar I wanted to get a solar panel and together we would use it to run some of there devices. But instead of just buying a panel I found solar cells on eBay for $1 a Watt so that is now what I have.
Now to the questions;
  1. Is there a website/book that is great at walking us threw putting the cells together into a panel, making an enclosure?
  2. Is a charge controller always necessary or could a reversed diode work just fine if I have a constant load to keep from over charging?
Thanks,
Richard J. Crews
The search terms you might use here to find that information are "evergreen cells" and "Ebay cells"
Did you try a search? Go HERE
and read that, then if you really have some researched questions you don't understand
return to ask a question worthy of our time to answer. This post is Read Only.
« Last Edit: February 17, 2008, 02:47:16 PM by (unknown) »
