Author Topic: Solar Panel Laminate (this may be redundant!)  (Read 990 times)
sathigpen
« on: January 07, 2005, 01:50:25 AM »
Hello,
I've attempted to bring this up before, so I may be *redundant here, BUT...
Does anyone know of any good sources for *laminating over solar cells on the =>front of the panels?
The plastic sheeting they sell at Home Depot, etc. looks way too milky.
Sam.
« Last Edit: January 07, 2005, 01:50:25 AM by (unknown) »
tcrenshaw
Re: Solar Panel Laminate (this may be redundant!)
« Reply #1 on: January 06, 2005, 08:06:30 PM »
That milky coating is a thin plastic sheet which is on both sides of the Plexiglas to protect it. You peel it off and have clear Plexiglas.
« Last Edit: January 06, 2005, 08:06:30 PM by tcrenshaw »
tcrenshaw
« Reply #2 on: January 07, 2005, 05:25:17 AM »
Just realized that you may be talking about the plastic used in protecting pictures and such. This will clear once heated. The stick on kind will stay milky. I think if you read more postings you'll find these two items not suitable for use on the cells because of expansion and contraction.
« Last Edit: January 07, 2005, 05:25:17 AM by tcrenshaw »
sathigpen
« Reply #3 on: January 07, 2005, 07:11:04 PM »
Yes, I was reading the other thread on expansion and contraction...  I'd like something to lay over the cells, seal, and then suck out excess air bubbles with a vacuum hose.
Sam.
« Last Edit: January 07, 2005, 07:11:04 PM by sathigpen »
pyrocasto
« Reply #4 on: January 08, 2005, 06:09:26 PM »
I believe it's exp/cont material itself, but I'm not positive.
If you could vaccum pack the material it would be nice
« Last Edit: January 08, 2005, 06:09:26 PM by pyrocasto »
