Author Topic: Better Homemade Panels  (Read 8467 times)
springgrove
Re: Better Homemade Panels
« Reply #33 on: October 13, 2009, 08:00:49 AM »
Thought I would throw in the cost.
Cells   75.00
Glass   50.00
SiliconeII  and Such  45.00
Aluminum Channel 15.00
Total  185.00
« Last Edit: October 13, 2009, 08:00:49 AM by springgrove »
wingman1776
« Reply #34 on: October 14, 2009, 06:08:28 AM »
great looking panel how many watt panel is that ?
« Last Edit: October 14, 2009, 06:08:28 AM by wingman1776 »
springgrove
« Reply #35 on: October 14, 2009, 04:28:27 PM »
Don't know yet.  When I get home from work it's already dark (6:00 PM).  I hope to do some testing this weekend. Hopefully we get some sun.  Winter is on the way.
« Last Edit: October 14, 2009, 04:28:27 PM by springgrove »
springgrove
« Reply #36 on: October 17, 2009, 11:30:35 AM »
Saturday 10-17-2009 1:00 PM (Testing Time)
The sun was in and out so I decided to do some testing.
Open circuit voltage 21.1 VDC
Max shorted current 3.79 Amps DC
Happy with the results.  Again the unit felt very solid as I carried it around.
« Last Edit: October 17, 2009, 11:30:35 AM by springgrove »
springgrove
« Reply #37 on: October 17, 2009, 11:41:05 AM »
Oh, forgot to add that the outdoor temperature was 48 degrees Fahrenheit.
« Last Edit: October 17, 2009, 11:41:05 AM by springgrove »
dubz
« Reply #38 on: October 17, 2009, 04:18:56 PM »
Just making similar panels using qsil 218 from ACC silicones...
http://www.acc-silicones.com/products/encapsulants/opticallyclearsiliconeencapsulants.ashx
 its a 2pack Optical clear silicone encapselent for solar cell encapselation.. it works excellent.. wil post spme photsos soon... had 2KG as a sample :-) for free!!
« Last Edit: October 17, 2009, 04:18:56 PM by dubz »
springgrove
« Reply #39 on: October 17, 2009, 07:29:31 PM »
Good luck Dubz.  Please post how it goes.
I'm on to the next step, making a mount for the panel (panels).  I don't want to put it on the roof and plan on a rack for the yard.  If anyone has any ideas please post.
« Last Edit: October 17, 2009, 07:29:31 PM by springgrove »
mfisch2001
« Reply #40 on: November 04, 2009, 04:53:40 AM »
   Nice looking panel. I hope it lasts. I have the cells and have been debating on the best way to make a panel. I was a process engineer for an electronics company and used many types of potting compounds. There are 2 types of 1 part silicone, one type releases Acetic acid when curing - this is your everyday silicone. It usually says it on the package and has the vinegar smell. The other type is for electronics. Both absorb water from the air to cure( and release a byproduct), which is why they recommend a max layer thickness of 1/4 inch or so. In a sandwich construction like this the silicone away from the edges may never truly cure which affects its mechanical and electrical properties. The specified properties are for a fully cured product.
   A 2 part silicone such as Sylgard would be a much better potting compound. Also since the black cells will heat much faster than the front glass, a very soft silicone is preferred over caulking type silicone to prevent cracking due to thermal expansion. Also if there is an impact or deflection of the front glass, there is less chance of cell damage with the softer silicone. We have large hail here so I have been hesitant to use any design which places in contact with (or bonds) the cells to the front glass.
   My plan was to bond the cells to the rear glass with a dab of silicone in the center, leave some of the tile spacers in place to support the front glass, put in some desiccant seal with silicone.
   I will be watching your thread and hopefully you will have some results by the time I actually build mine.
Mike
« Last Edit: November 04, 2009, 04:53:40 AM by mfisch2001 »
