Author Topic: My solar panel puts out 24/12-volts 350 mA  (Read 1089 times)
NC Ghost
« on: December 27, 2004, 06:18:46 PM »
(blank)
« Last Edit: December 27, 2004, 06:18:46 PM by (unknown) »
Re: My solar panel puts out 24/12-volts 350 mA
« Reply #1 on: December 27, 2004, 11:56:06 AM »
Yes, it can be done.
My quicky (ugly) setup works well for 2 to 8 AAs, and 2 cam corder batteries. Use it when fishing. About $10 in parts, plus the panel.
There is not enough info to tell you how.
Does the camera charge the batteries? Does it hold 6 AAs?
Where did the 12v 250mA come from?
Is there a seperate charger?
I would not recommend connecting the panel to the camera.
« Last Edit: December 27, 2004, 11:56:06 AM by ghurd »
skravlinge
« Reply #2 on: December 27, 2004, 12:27:28 PM »
Its OK to recharge batteries for the camera, but connecting  a panel to the camera I think has risks, get at least a spare camera.
« Last Edit: December 27, 2004, 12:27:28 PM by skravlinge »
NC Ghost
« Reply #3 on: December 27, 2004, 01:09:24 PM »
The camera has the six rechargeable NI-MH batteries inside that can be charged through a plug at the bottom.  The charge can be either through a 120ac to 12dc 300 mA power supply or a 12-volt solar D panel.  The panel I have is a ICP Global Technologies .  The Wp = 5 Watts  Voc = 24 volts Isc = 350 mAmps...the next line down reads Vspec = 15 volts I@Vspec =324 mAmps...System Voltage Maximum = 50 Volts.
Thanks for answer and more help I hope
« Last Edit: December 27, 2004, 01:09:24 PM by NC Ghost »
« Reply #4 on: December 29, 2004, 09:25:17 AM »
A simple solution would be to connect the panel to the input of a 1 amp 7809 voltage regulator,
and the output to a 6 AA holder.
Remove the batteries from the camera and place them in the holder. Point the panel toward the sun.
This would allow a slight overcharge of 0.05v for each battery, I wouldn't worry about it myself, unless the batteries were left charging for days at a time.
To ensure no overcharge, a 2.5 ohm resistor could be placed in series between the batteries and 7809, but this will slow the charging considerably.
Another way to ensure no overcharge is to use the first example, but use a 7808. However, this will result in never reaching a full charge.
It will take more than a day of good sun to get them full.
Most 7800 type voltage regulators will try to keep the voltage as high as they can up to their rating. A 7809 will try to stay at 9 volts (7808 is 8 volts). If it can't reach 9 volts (because the panel can't make enough current to instantly get the battery to 9 volts) it will do what it can, say 7 volts.  This is good anyway, because you don't want the batteries getting so much current they instantly go up to 9 volts.
The wrong regulator.  Some 7809's will stay at 9v if they can, but if they can't maintain 9v they shut off. You don't want this kind. The problem is you can't tell which is which, or at least I can't.
It would be wise to use a heat sink on the regulator.
I find TO-220 style regulator easier to use for something like this.
Don't go less than 1 amp rating for the regulator.
The regulators call for 2 capacitors, but I never needed them for this type of use, so I don't use them.
It's rare I get the 'wrong' type of regulator, so what ever one they have usually works for this.
Give it a try. Cheap and easy. The regulator has 3 wires, one to the panel positive, one to the battery positive, and one to both negatives.
« Last Edit: December 29, 2004, 09:25:17 AM by ghurd »
