Author Topic: solar  (Read 979 times)
farmbo
solar
« on: February 02, 2005, 02:43:11 AM »
  if you want a cheap solar tracker...check out
mother earth news..issue # 48...pages 110 -112..
« Last Edit: February 02, 2005, 02:43:11 AM by (unknown) »
pyrocasto
Re: solar
« Reply #1 on: February 01, 2005, 11:49:02 PM »
I personally think using an actuator and tracker circuit on the same setup is easier, but it would cost more than $35 if you're not good at scrounging.
Pros and Cons:
Actuator Circuit Pros: Programable, collects maximum power.
                 Cons: uses electricity, few more parts to break down.
Freon Tracker Pros: uses no electricity.
              Cons: doesnt work until the panel heats up, which may take awhile since it's facing the opposite direction of the sun every day. Better hope you dont get a leak as well.
« Last Edit: February 01, 2005, 11:49:02 PM by pyrocasto »
jimovonz
Re: solar
« Reply #2 on: February 02, 2005, 01:51:50 AM »
I always favoured the old water, bucket, pulley, spring + irrigation timer for a cheap but effective tracker.
« Last Edit: February 02, 2005, 01:51:50 AM by jimovonz »
