Author Topic: Solar Panel Glass  (Read 1084 times)
Hansenman
Solar Panel Glass
« on: March 27, 2005, 02:50:00 AM »
Hello Everyone,
I'm looking at building my first panel using ebay cells, but am having some difficulty locating some reasonably priced glass. I have been able to locate a source of used glass and have have found some used for shower doors. It has the advantage of being tempered, however it is of the "wavy" type used to obscure someone's view looking through. I don't think this would affect the light transmission to the cells. Any thoughts?
« Last Edit: March 27, 2005, 02:50:00 AM by (unknown) »
Psycogeek
Re: Solar Panel Glass
« Reply #1 on: March 26, 2005, 10:44:38 PM »
well how do your cells respond to having less light in some places, and more in others?
i know that any Milky in the stuff (diffusion) just totally wacks light, but that wavey stuff, would just prism it about in waves, having hot and shadowed places.
and even tempered, the low and high places would not aonly refract light all about, but would reduce its total strength.
« Last Edit: March 26, 2005, 10:44:38 PM by Psycogeek »
DERFMOOSE
« Reply #2 on: March 27, 2005, 08:29:08 AM »
 one way to get glass find someone replacing windows
the double type thes have usealy good sized glass
« Last Edit: March 27, 2005, 08:29:08 AM by DERFMOOSE »
johnagony
« Reply #3 on: April 03, 2005, 12:03:02 PM »
Can it be Lexan-polycarbonate? I'm about to venture upon my first home brew.
Also, a rear reflecting surface, eg aluminium foil, to throw light back into the unit?
Since limbs fall off trees and nasty children may be a problem, a hardware cloth protector?
I'm new here & picking braynes, promise to report in, thanks. John
« Last Edit: April 03, 2005, 12:03:02 PM by johnagony »
Psycogeek
« Reply #4 on: April 11, 2005, 12:52:35 PM »
i was told that acrylics (plastic glass) will reduce the thing 8%
i have not tested that yet, but i BELIEVE.
my little first pannel is going to be acrylic, or abs, or poly carbonate anyway, because i am not mounting it right away. i was planning on an at LEAST having to replace it every 5 years, as it will yellow, and then be as easily cracked as glass, brittle from the sun.
but Tempered glass, it the only strong type of glass, and its pretty good.
« Last Edit: April 11, 2005, 12:52:35 PM by Psycogeek »
