Author Topic: Where is this Otherpower Solar article??????  (Read 1270 times)
erichtopp
« on: November 11, 2005, 09:23:35 PM »
I searched the web using Google for "homebuilt solar" and "homemade solar". This was the only article I could find on the web of how to build photovoltaic solar cells. It pointed me right back here to the Otherpower.com. All I can find is these pictures but can't find the article. Someone has done an excellent job of building these photovoltaic solar panels.
http://www.otherpower.com/images/scimages/465/Solar_021a.jpg
http://www.otherpower.com/images/scimages/465/Solar_020a.jpg
http://www.otherpower.com/images/scimages/465/Solar_017a.jpg
http://www.otherpower.com/images/scimages/465/Solar_016a.jpg
http://www.otherpower.com/images/scimages/465/Solar_015a.jpg
http://www.otherpower.com/images/scimages/465/Solar_013a.jpg
http://www.otherpower.com/images/scimages/465/Solar_012a.jpg
http://www.otherpower.com/images/scimages/465/Solar_005a.jpg
Can anyone point me to the article on how these solar panels were built here at the Otherpower.com????? Thank you, Erich
« Last Edit: November 11, 2005, 09:23:35 PM by (unknown) »
Re: Where is this Otherpower Solar article??????
« Reply #1 on: November 11, 2005, 03:38:02 PM »
  iFred has one somewhere but here is a good
link that may help.......
http://www.jeff7.com/projects/solar/solar%20prototypes%20page%202.htm
               ( :>) Norm
« Last Edit: November 11, 2005, 03:38:02 PM by Norm »
stop4stuff
« Reply #2 on: November 11, 2005, 03:46:11 PM »
« Last Edit: November 11, 2005, 03:46:11 PM by stop4stuff »
stop4stuff
« Reply #3 on: November 11, 2005, 03:47:11 PM »
...erichtopp
« Last Edit: November 11, 2005, 03:47:11 PM by stop4stuff »
iFred's website?? and solar cells?
« Reply #4 on: November 11, 2005, 04:27:29 PM »
 Yep...that looks like the pics that he is
referring to but iFred also had an article on his
website that the ones selling reject solar cells
liked so much that they referred iFred to their customers
or so I understood....
  Maybe iFred can clarify this ...I can't seem
to find that particular part ??
                   ( :>) Norm.
« Last Edit: November 11, 2005, 04:27:29 PM by Norm »
erichtopp
« Reply #5 on: November 11, 2005, 09:59:03 PM »
Thanks for the help and links on this one guys. You've answered all of my questions throughly. Rgds, Erich
« Last Edit: November 11, 2005, 09:59:03 PM by erichtopp »
Jeff7
« Reply #6 on: November 12, 2005, 11:56:43 AM »
Might I say that my design needs some refinement. :)
It's detailed in there fairly well, though the page needs an update. I'm at college, and only have second-hand reports of my second prototype back home - the "future revision" I spoke of.
The second revision ditched the wooden dowels in favor of aluminum ones. I also used Devcon Metal Welder epoxy, which is supposed to stick to aluminum and polycarbonte very well. My design's weakness is the corners. I would have liked a single piece to go over each corner, but I couldn't find anything suitable. My "solution" was 3 separate pieces over each corner, and covered it with Goop contact cement. It held up ok in the summer heat (yeah, this thing was put outside some time ago) as well as a few stays in a freezer, without breaking a seal.
But, after maybe a few weeks outside, something broke, and it started getting condensation. I know there are some people here using ventilated panels, but that still makes me wary. The professional panels appear to go to great lengths to seal their panels. So there must be good reason for that. Sealing something from nature is quite diffcult - nature is pretty harsh. Temperatures below 0F one part of the year (lower air pressure inside the panel) to 100F in the summer, and even hotter inside the panels, which makes them want to burst. Add in the effects of ultraviolet radiation, rain, snow, hail, and wind....weathering is pretty harsh.
And I know, from both reading and from experience, that solar cells do not like moisture. The silkscreen lines on the front will start to peel away, which will reduce output.
When I get home for Thanksgiving, I'll have a look at my solar panel and see what went wrong.
Ideally, and I just thought of this, the corners would have their reinforcement done from the inside as well as the outside. This would protect against bursting pressure in high heat, and from crushing pressure in cold weather. The pressure inside got very high in summer sunlight, with the inside of the panel well over 140 degrees Fahrenheit. The polycarbonate front bulged out considerably, and was not easily pressed back down.
Bear in mind too, this was only a small prototype panel. Constructing a full-size panel would be somewhat expensive, (though cheaper than a professional panel) assuming new material was used - aluminum backing and UV-resistant polycarbonate front - and it would be fairly difficult to assemble it quickly and accurately, before the epoxy set.
Why all the effort to make such a robust panel? First, quick explanations - I chose aluminum because it resists weathering naturally. Polycarbonate is impact resistant, quite transparent, and can be treated to withstand UV radiation. I wanted it durable, because what's the point of saving 50% on the cost of a professional panel, when the homemade panel might only last a year, whereas the professional panels have 10-year warranties on parts (and 25-year warranties on output)?
I'd love to give my panel one last prototype, but that's going to be quite some time off. It looks like I'll be in college about 3.5 years yet, so that's where all my time and money's going to have to go.
« Last Edit: November 12, 2005, 11:56:43 AM by Jeff7 »
