Author Topic: What do you think about Eliminator solar panel $9.99, 12V @ 1.8W  (Read 1504 times)
Speo
Hi guys,
This panel is on Sale at Canadian Tire: link
Does somebody know more about this panels?
Thanks,
Speo
« Last Edit: April 01, 2006, 02:45:36 PM by (unknown) »
Shadow
Works for me.
« Reply #1 on: April 01, 2006, 07:59:04 AM »
I have one hooked permanatley to my tractor and also one on my boat, batteries are never dead when I go to start them.I used to have to boost my tractor every spring after sitting all winter,but not any more.
« Last Edit: April 01, 2006, 07:59:04 AM by Shadow »
« Reply #2 on: April 01, 2006, 09:38:38 AM »
its a good deal compared to the 80W panel they have for sale at  $700.
and 45( 1.8W) = 81W of those will only cost $450 ..
« Last Edit: April 01, 2006, 09:38:38 AM by willib »
AbyssUnderground
Re: What do you think about Eliminator solar panel
« Reply #3 on: April 01, 2006, 01:36:34 PM »
I have 2x 12v 1.5w panels charging a 17.5Ah lead acid and these panels look exactly the same although the specs are 1.8w not 1.5w and I got mine in the UK not CA.
Mine are 1.5w not 1.8w.
They give out roughly 125mA at full capacity.
Open circuit voltage is 21v.
Built in blocking diode.
I use two connected in series when light levels are low although they work fine in series even when they are in bright light.
I use them in parrallel when there is bright sun and im there to swap them.
Remember mine might not be the same but from the picture they look identical.
Hope this helps.
« Last Edit: April 01, 2006, 01:36:34 PM by AbyssUnderground »
asheets
« Last Edit: April 03, 2006, 04:12:37 PM by asheets »
