Author Topic: Great output or not?  (Read 1110 times)
mjchee
« on: April 07, 2006, 09:06:19 PM »
 During a good afternoon when the sun is at it's average high, I noticed that my amp reading for my panels were putting out at 40 plus amps. Is that pretty good or what? I would estimate that my solar panels are at an average of 19 volts. What do you think about my amp readings? I figure the more panels you have, the better you would be off in recharging the battery storage, at a faster pace, with a good working charge controller, right?
« Last Edit: April 07, 2006, 09:06:19 PM by (unknown) »
AbyssUnderground
Re: Great output or not?
« Reply #1 on: April 07, 2006, 03:47:22 PM »
It depends on how big the panels are as to whether 40 amps is good or not, but I would certainly think it is. Thats around 400w at 12v if im not mistaken. (19v panels are usually 12v).
« Last Edit: April 07, 2006, 03:47:22 PM by AbyssUnderground »
thirteen
« Reply #2 on: April 09, 2006, 05:23:54 PM »
do you need to redirect your solar panels into the direct sun
« Last Edit: April 09, 2006, 05:23:54 PM by thirteen »
MntMnROY 13
mjchee
« Reply #3 on: April 10, 2006, 08:46:51 AM »
 I think I placed it on equalization when I got that reading and I will calculate the panels to figure out the readings which shall be just estimates. I'm using the Arco and Carrizo panels and they seem to be working fine. I had them for quite a few years now. My battery bank are 12 volt deep cycle batteries and I have 10 in parallel connection. I'll send more info as soon as make some more calculations.
« Last Edit: April 10, 2006, 08:46:51 AM by mjchee »
