Author Topic: generating power from the sun  (Read 1851 times)
eraser1
« on: November 23, 2006, 05:40:40 AM »
We can make wind generators to capture the energy of the wind and produce power but what can be homemade to capture energy from the sun ( heat or light) to produce electrical power, The only option i think we have at the moment is to buy solar panels?
I am building a solar collecter to heat water ,but is there anything that can be home built at home to produce electrical energy from the sun ???
« Last Edit: November 23, 2006, 05:40:40 AM by (unknown) »
mettleramiel
Re: generating power from the sun
« Reply #1 on: November 22, 2006, 11:45:29 PM »
Yes there is, but nothing really usable. There is a link to a book on how to do this right on this site
http://www.forcefieldmagnets.com/catalog/product_info.php?cPath=21_29&products_id=131.php?cPath=21_29&products_id=131
« Last Edit: November 22, 2006, 11:45:29 PM by mettleramiel »
disaray1
« Reply #2 on: November 23, 2006, 05:31:47 AM »
  Not everyone has the needed tools, equipment and know how to build this "at home", but a small one of these..(this is a cool sight)
  http://www.stirlingenergy.com/imagesdet.asp?type=allsolar&imageID=11
 is feasible...I think. A couple of folks here are working on their Stirling engines now. Add a C band satellite dish lined with mylar and a PMA on the Stirling, and start your own power station.
 disaray
« Last Edit: November 23, 2006, 05:31:47 AM by disaray1 »
« Reply #3 on: November 23, 2006, 09:16:44 AM »
  I remember I read in Popular Science many years
ago that they had mylar parabolic mirrors vacuum
sucked the mylar into the parabolic shape a
regular farm just like a windmill farm ....
Each one made steam to be used by a central
steam turbine to generate electricity.
maybe they still have them? or were they
replaced by the windmills?
         ( :>) Norm.
« Last Edit: November 23, 2006, 09:16:44 AM by Norm »
thefinis
« Reply #4 on: November 23, 2006, 06:24:57 PM »
There are several options but the most likely ones are sterling motors or turbines with a solar collector driven by steam or some other coolant medium like one of the refrigerants. These are not at the build it at home stage yet unless you have a really nice shop and know how to use it. Give it a few more years of high energy prices and you should see some of these make a better showing. If oil prices fall to old price levels it will put it all on the back burner again.
I would like to see a solar steam unit that makes electricity and pure drinking water. Pure water may be a more valuable item in many areas than elecricity.
Finis
« Last Edit: November 23, 2006, 06:24:57 PM by thefinis »
boB
    • boB
« Reply #5 on: November 23, 2006, 11:29:02 PM »
Since other things have been mentioned already...
Wind energy IS power from the sun !   Works at night too.
boB
K7IQ
www.wirelessfusion.org
« Last Edit: November 23, 2006, 11:29:02 PM by boB »
« Reply #6 on: November 24, 2006, 01:50:56 PM »
eraser1;
 As you can see from the posts there are quite a few things that can be done.
Some of it will come from your own imagination.
Sice you're already building a solar heater for your water you could build into it some type of co-generation system where a part of the design is to heat a much smaller diameter tube of water wound so that it gets to steam hot, this will do too things.
  1. ) boil the water so that it is safer to drink
  2. ) steam for running a steam powered generator.
Or if you wanted to leave the current box alone, go get a stainless steel mixing bowl from the dollar store, don't get the better 1/2 mad by taking one from the kitchen ;-) find the focal point and use the heat focused on that point to do the water distilling and steam production.
Sky's the limit for doing stuff with solar heat. <<< Pun intended>>>
Hope this helps
« Last Edit: November 24, 2006, 01:50:56 PM by Bruce S »
