Author Topic: Translucent/stick-on solar PV  (Read 4155 times)
« on: May 15, 2008, 03:29:36 PM »
After finding out about bifacial solar panels here a little while ago, I've started looking to see if there's any such thing as stick-on PV for windows for partial shading in summer, etc.  (I thought that those Sanyo and other bifacials looked rather pretty in 'transmission'.)
I'm guessing that some of the lighter semi-flexible polycrystalline panels might do it, but are unlikely to be attractive in rear view nor lightweight nor robust (ie just like me!)...
Also, they are unlikely to be optimised for whatever spectrum makes it through one or two panes of window glass I imagine.
My hamfisted Google searches haven't turned up anything specific so far.
This would mainly be experimental/novelty value for me right now, but there might be some useful mileage in such a product of course...
Applications as well as shading an overly-sunny room: charging phones, electronic mosquito repeller, adding a few Watts to an existing off-grid system, pumping a few Watts into the grid with a tiny grid-tie...
« Last Edit: May 15, 2008, 03:29:36 PM by (unknown) »
kurt
    • website
Re: Translucent/stick-on solar PV
« Reply #1 on: May 15, 2008, 12:46:58 PM »
there are some stick on panels that are supposed to be just peal and stick to roofs coming soon but they are vaporware at the moment. so we will see...
« Last Edit: May 15, 2008, 12:46:58 PM by kurt »
« Reply #2 on: May 15, 2008, 01:11:47 PM »
Hi Kurt,
Do you mean the UniSolar laminate stuff for example?  Maddeningly about 5cm too long for my flat porch roof or I'd already have gone out and bought some and stuck it down!
But if so, that's not quite what I meant.
Rather, PV designed to let some light through like a partial sunshade.
You can definitely get this (decorative and functional) stuff in rigid glass from several sources, but what I have in mind right now is sticking such a thing, reversibly, onto the inside or outside of, for example, my large glass patio doors that in summer otherwise let in too much light and heat.
« Last Edit: May 15, 2008, 01:11:47 PM by DamonHD »
kurt
    • website
« Last Edit: May 15, 2008, 01:23:12 PM by kurt »
« Reply #4 on: May 15, 2008, 02:31:22 PM »
Yes, also very interesting (and would nicely fit my flat roof, though I think triple-junction would do better, but I wrote to the company already anyway!) but still not quite right for what I have in mind.
But please keep kicking out these examples, because very soon you'll turn up something that I've missed I'm sure!  B^>
Thanks again.
« Last Edit: May 15, 2008, 02:31:22 PM by DamonHD »
« Reply #5 on: May 15, 2008, 06:23:56 PM »
Still vaporware it seems
http://www.renewableenergyworld.net/rea/news/story?id=45641
solar pv window tint (organic and half the output of silicon based
« Last Edit: May 15, 2008, 06:23:56 PM by dnix71 »
« Reply #6 on: May 16, 2008, 01:23:38 AM »
Well, you may indeed have the answer there...  Vapourware only at the moment...
I did see another very recent research grant for something similar.
Still, I'l keep looking!  B^>
« Last Edit: May 16, 2008, 01:23:38 AM by DamonHD »
« Reply #7 on: May 16, 2008, 09:13:44 AM »
It will have to be the outer pane of a double-pane window.  The the above-bandgap part of the energy of the absorbed light will appear as heating of the coating, so you want that on the outside of the window - at least in the summer.
« Last Edit: May 16, 2008, 09:13:44 AM by Ungrounded Lightning Rod »
« Reply #8 on: May 16, 2008, 09:15:16 AM »
Make that "you want it on the outside pane".
Putting the coating on the inside part of the outside pane will protect it from the environment very nicely.
« Last Edit: May 16, 2008, 09:15:16 AM by Ungrounded Lightning Rod »
« Reply #9 on: May 16, 2008, 09:39:28 AM »
That would rather preclude it being a DIY job, or being taken off in the evening for example, if I understand you!  B^>
« Last Edit: May 16, 2008, 09:39:28 AM by DamonHD »
« Reply #10 on: May 16, 2008, 07:19:00 PM »
It only stops half the light.  I think the thermal windows on our Nevada house stop about 2/3 and they don't noticeably hamper visibility at night.  (Half the energy is about 3db, which is barely detectable in the logarithmic response of the eye.)
« Last Edit: May 16, 2008, 07:19:00 PM by Ungrounded Lightning Rod »
« Reply #11 on: May 17, 2008, 02:10:01 AM »
Indeed, I can understand that.  And it's a nice idea.
But the implication is still that I'd have to get specially-constructed double-glazed doors, yes, which would be fiendishly expensive I'll bet!
« Last Edit: May 17, 2008, 02:10:01 AM by DamonHD »
« Reply #12 on: May 17, 2008, 06:41:42 AM »
Lateral thought: maybe I could drape one of these outside the window(s) in question as a sunshade?
http://www.powerfilmsolar.com/products/military/armytents/quadrantdatasheet.htm
Anyone know of other weather-proof lightweight fabric-based stuff like this?
« Last Edit: May 17, 2008, 06:41:42 AM by DamonHD »
bob golding
« Reply #13 on: May 17, 2008, 02:07:58 PM »
http://www.selectsolar.co.uk/panelrollandfold.php
the uk distributer of power film products in the UK. assuming half the price for getting someone in the US to buy them and post them might be just about worthwhile but its going to be an expensive sunshade. interesting technology all the same.
bob golding
« Last Edit: May 17, 2008, 02:07:58 PM by bob golding »
« Reply #14 on: May 17, 2008, 05:46:01 PM »
They're fiendishly expensive WITHOUT the solar panel - just with low-E glass and a frame.  If the low-E coating could be made as a solar panel without a price change you'd get the power for the cost of the extra wiring.  If not, you get it for that plus the price difference (presuming you were going to install low-E windows anyhow).
That delta might be far less than the cost of a full-blown panel assembly - glass, frames, wiring, mounting, ...
« Last Edit: May 17, 2008, 05:46:01 PM by Ungrounded Lightning Rod »
« Reply #15 on: May 18, 2008, 02:49:39 AM »
OK, indeed.
Well, if we have to have some custom-made double glazing done, and it is entirely possible that some of our 40-year-old falling-apart stuff is going to need repair or replacement, then I'll see if we can put in (say) some of Schott's laminate stuff in the outer pane.
« Last Edit: May 18, 2008, 02:49:39 AM by DamonHD »
« Reply #16 on: May 20, 2008, 05:09:40 PM »
Ouch!, the rollup solar is $30 US a watt (300 Pounds/20 watts)
It says you can walk on it. Sounds like military surplus.
« Last Edit: May 20, 2008, 05:09:40 PM by dnix71 »
