Author Topic: Outback Charger/Inverter, controlling charger  (Read 1007 times)
pepperhead1963
« on: May 26, 2008, 12:45:31 PM »
Is it possible to delay or set the conditions whereby the automatic charger kicks in and charges your batteries from grid?
Following scenerio comes to mind:
My batteries are at 11.9 volts and it is going to be a sunny day and my use will be low so I know by 2pm my batteries will be topped up.  It would be a shame for the charger to kick in, draw 10kw from the grid, and waste sun all day.  Conversely, it is a dark November day and the batteries are 11.9, I want them topped up via the grid.  I would like to be able to manually override the charger, by flipping a switch or by having a delay, ie), it the batteries stay at 11.9 for more than 2 hrs, charge them
« Last Edit: May 26, 2008, 12:45:31 PM by (unknown) »
Re: Outback Charger/Inverter, controlling charger
« Reply #1 on: May 26, 2008, 07:04:58 AM »
A little looking around over at outbackpower.com would yield your answer.
Basically: With a Mate you can program the FX series Inverters to do what you wish.
Might be worthwhile to check that out.
« Last Edit: May 26, 2008, 07:04:58 AM by TomW »
electronbaby
    • Windsine.org
« Reply #2 on: May 26, 2008, 07:10:17 AM »
yes. You can set the chargers to draw from grid power and charge your batteries based on their voltage, and/or the clock. Pretty sure they wont do time-or-day selling, but im pretty sure you can do it on the charging end. If you want the solar to always supply a charge first, program the charge controller parameters slightly different than the grid charger. There is many ways to set up and program these systems.
hope this helps.
« Last Edit: May 26, 2008, 07:10:17 AM by electronbaby »
Have Fun!!!  RoyR KB2UHF
pepperhead1963
« Reply #3 on: May 26, 2008, 08:25:26 AM »
Yup, I just went over and downloaded one of their PDF manuals, and the charger can be set to  OFF/Auto/ON, with the default to Auto
Thanks guys
« Last Edit: May 26, 2008, 08:25:26 AM by pepperhead1963 »
