Author Topic: solar panel diy backing  (Read 1005 times)
lookrent
« on: July 30, 2008, 10:11:29 PM »
hi guys. does anyone have any suggestions on what material to use as backing on a do it yourself panel?i am just geting into the field and need something inexpensive to build my first panel, second does anyone have a diagram of where to put a blocking diode.
« Last Edit: July 30, 2008, 10:11:29 PM by (unknown) »
howlet
Re: solar panel diy backing
« Reply #1 on: August 15, 2008, 02:50:08 AM »
Poly Vinyl Flouride (PVF) Commonly known as Tedlar is usually used as a back sheet in standard silicon crystalline cell modules. Included is a photo of one of the first modules that I made with a laminator. Ive since had to develop methods to insure all of the small air bubbles are evacuated during lamination. JB
« Last Edit: August 15, 2008, 02:50:08 AM by howlet »
lookrent
« Reply #2 on: August 15, 2008, 07:37:37 AM »
I have seen tedlar sheets on e bay however I was not sure how they are used. are the sheets rigid enough to attach cells to without some other material behind them and an outter frame to support the finished panel? thanks for any info you can provide.
« Last Edit: August 15, 2008, 07:37:37 AM by lookrent »
