Author Topic: Off grid Greenhouse Inflation Fan Application  (Read 17201 times)
Re: Off grid Greenhouse Inflation Fan Application
« Reply #33 on: June 21, 2009, 10:03:54 PM »
The one I mentioned may be the 1st one on page 54.
Wow!  Fan.  12V, 20.5W, 2.53" H2O.  Page 41.
The first blower on page 66 is impressive, if it has no leaks.  12V, 170ma, 0.97" H20, 2W (Two Watts!).
« Last Edit: June 21, 2009, 10:03:54 PM by ghurd »
Kittylee4
« Reply #34 on: June 28, 2009, 03:25:41 PM »
      http://www.hightunnels.org/ForGrowers/LaborSavingIdeas/AmishPlasticInflation.htm
Check this out. No electricity needed and it only works when you want it to--when the wind blows. (Let me know if you find instructions as to how to build this, because I want one....maybe you can figure it out just by looking at the photo.)
« Last Edit: June 28, 2009, 03:25:41 PM by Kittylee4 »
mooselick7
« Reply #35 on: September 28, 2009, 02:09:29 PM »
Since this thread has been useful to others (I have seen info in this thread used by other growers), I have an update.  Here is a way to reduce the power drain.
http://www.sunnyjohn.com/photos/devices_tools/dt_inflate_blower/index.htm
Normally, these fans run 24/7; however, with this setup, it will run only to provide the required pressure needed for inflation.
« Last Edit: September 28, 2009, 02:09:29 PM by mooselick7 »
« Reply #36 on: September 28, 2009, 02:30:16 PM »
Did you try any of the DC muffin fans in your green house?
« Last Edit: September 28, 2009, 02:30:16 PM by ghurd »
