Hi
The second photo is of the complete setup. The silver bit on the left is the inverter, 600W pure sine wave. The chinese charge controler needs no explanation, it comes with a 200W Bergey look alike. The two solar charge controlers, the left one is the one that does the work, the one on the right is just set up to monitor battery state of charge. The busbar on the top left started out life as a single unit but I removed a bit from the middle I use philips screws for the positive side and ordinary screw heads for the negative side.
The white plastic unit in the front of the inverter is a power meter monitoring the output load and voltage, the small flat device beneath that is an incrementing KWh meter. The ameter is only temporary and shows the current from the panels, 3.5A the voltmeter was cycling between 13.3 and 13.5
The solar panels are from two different suppliers, hence the difference in size. They are mounted in an aluminium frame on home made brackets. The amorphic panel in the background is not connected I made it from five unmounted panels, but had trouble keeping the water out.
Thanks for the comments
Brian
