Author Topic: How many Amp/Hrs are these?  (Read 1340 times)
olvvlo
« on: May 23, 2006, 07:52:37 AM »
can anybody tell me how many amp/hrs these battery is maybe?
They measure 30x30x16cm and are both 6v.
I acquired them off a friend who said a year ago the electrolyte was replaced after they had dried up!  He then left them uncharged for the rest of the year!
I checked the voltage when I got home and each cell registered about .9V giving 2.7v per battery.
I put them on charge overnight wired in series for 12v with the charger indicating about 7 amps.
This morning they were drawing 3 amps. Each battery reading 6.7 volts.(13.4v)
Is this an indication that they may be good still?
and/or is there anything else I could do that may save tham?
There are two more batteries making a total of four and therefore could save me a lot of money.
« Last Edit: May 23, 2006, 07:52:37 AM by (unknown) »
thunderhead
  • Country: ie
Re: How many Amp/Hrs are these?
« Reply #1 on: May 23, 2006, 04:24:23 AM »
If they drew 7A overnight (12 hours) they'd be 7A x 12h = 84Ah.  If they drew an average of 5A overnight, they'd be 5A x 12h = 60Ah.
If that's good or not probably depends on how much lead there is in them: my 12v/100Ah batteries weigh about 40kg, so if your batteries weigh the same they should be capable of storing something around 200Ah.
Keeping them on a good float charge for a while might help them, or you might try pulse-charging them or zero delta voltage charging them.  Circuits to do this can be found by searching through this site.
But the fact that they drew 7A on charge is a good sign -- lead acid batteries tend to die by sulphation, which prevents them from being charged.
« Last Edit: May 23, 2006, 04:24:23 AM by thunderhead »
