Author Topic: Golf cart battery equalization questions  (Read 1506 times)
debequechute
« on: April 21, 2005, 12:45:26 PM »
As noted in the intro, the center string of 8 6V (generic, brand unknown) batteries has a specific gravity of 1275, but the upper and lower banks show about 1175. Water levels are about the same. I'm using a trace 4048 inverter as the charge controller from a generator input.
Question on equalization: would it be better to disconnect the center string and try to bring the other two up in SG before beginning equalization? Maybe one string at a time?
Is 62V about right for an equalization voltage on a 48V string?
Given the above SG readings, is it the center string with the higher SG doing all the work or the other two?
« Last Edit: April 21, 2005, 12:45:26 PM by (unknown) »
debequechute
Re: Golf cart battery equalization questions
« Reply #1 on: April 21, 2005, 11:49:38 AM »
To further confuse me: I just broke apart the strings to measure each, and all three are right at 50.2V no load/charge. Doesn't that mean they are all fully charged? Why would the specific gravity be so far off when the water levels are essentially equal? These batteries are all from the same lot.
« Last Edit: April 21, 2005, 11:49:38 AM by debequechute »
veewee77
« Reply #2 on: April 21, 2005, 09:04:58 PM »
question. . .
in the circuit. . . the batteries are series strings paralleled together, right?
OK. is the charge wires in the center of the strings like:
Example 1
   here
8 - 8 - 8
   here
or are they wired like this:
Example 2
here
8 - 8 - 8
      here
If the charge wires are in the center, it could be that those are getting the best charge.
Adjust the wiring as in example 2 so that each battery string has a better chance for an equal charge.
Doug
« Last Edit: April 21, 2005, 09:04:58 PM by veewee77 »
Off grid in Tonopah
« Reply #3 on: April 22, 2005, 02:21:54 AM »
I think the difference in the S.G. your seeing is stratification and a good equalization should help out
                                                   Bob
« Last Edit: April 22, 2005, 02:21:54 AM by Off grid in Tonopah »
whatsnext
« Reply #4 on: May 03, 2005, 11:42:37 AM »
It could also be that the batteries have been treated differeny over the years. Definately equalise batteries is series strings only. You can adjust SG later if it's a big issue to you.
John.......
« Last Edit: May 03, 2005, 11:42:37 AM by whatsnext »
