Author Topic: Exide Battery leaking at seal  (Read 2377 times)
peter altas
« on: March 10, 2010, 03:22:12 PM »
Some of them, ex Telecom, have been repaired with what looks to be a bitumen compound and then duct taped.  I've tried a waterproofing bitumous tape (Norton Flash-Tac) but it's getting through still.  This stuff is good but needs to warm up (eg. metal roofs) to work well.  Any other suggestions?  I'm just concerned about using anything that may attack the plastic.  From the MSDS the jar is SAN and the lid may be PE, according to Exide's tech they're both ABS.
« Last Edit: March 10, 2010, 03:22:12 PM by (unknown) »
Exide GNB Energystore 4RP1800NX2 1800Ah C100 @ 24V battery bank
2x Victron Multi Plus 24/3000/70 Inverter Chargers
3x Outback Power Flexmaxx MPPT solar charge controllers
3.4kW Solar PV Array (6x 175W Sharp, 12x 195W Solar Enertech)
Honda powered Gentech 4.4kVA petrol/LPG generator
zap
  • There's an app for that
Re: Exide Battery leaking at seal
« Reply #1 on: March 10, 2010, 07:41:42 PM »
You could try welding them.
A little more than half way down the page here:
http://www.chinadepot.com/batmanual.html
It's titled "HOW TO REPAIR HOLES AND CRACKS IN BATTERIES:"
From dnix71
http://www.fieldlines.com/comments/2009/6/2/225117/8125/1#1
From Ex Mek
http://www.fieldlines.com/comments/2005/5/3/233334/9995/6#6
http://www.fieldlines.com/story/2005/1/11/153224/887
I think welding would be doable.  I've never done it on a battery case but I've welded a lot of plastic.  On some plastic it works well, not so well on others.  ABS welds nicely.
« Last Edit: March 10, 2010, 07:41:42 PM by zap »
wpowokal
« Reply #2 on: March 11, 2010, 04:32:17 AM »
For them to part at this point implies that there has been some expansion of the positive plates from my experience with 650 A/h FanureX.
allan
« Last Edit: March 11, 2010, 04:32:17 AM by wpowokal »
peter altas
« Reply #3 on: March 11, 2010, 12:30:13 PM »
Thanks for the help.
I ended up getting in contact with a technical advisor at Dow Corning and he recommended their Silastic 732 compound.  Bit of hard work clearing off the bitumen (mineral turps and a lot of rags later), but the end result seems to look good.  Time will tell as to it's effectiveness.  The Flash-Tac came apart fairly easily in some sections, and didn't evenly bond to the plastic.
« Last Edit: March 11, 2010, 12:30:13 PM by peter altas »
