Author Topic: Battery behaviour in parallel  (Read 1357 times)
ch2
« on: July 11, 2006, 02:28:22 AM »
If you are charging two batteries set up in parallel, will they always see the same charge current? Say you had a charger capable of delivering 20 Amps, do the two batteries get 10Amps each or will one see a higher current (if it has a different charge for example)? I guess this has to do with the impedence of a battery and how that varies through the charge cycle.
Another question - how often do batteries go closed circuit?
« Last Edit: July 11, 2006, 02:28:22 AM by (unknown) »
altosack
Re: Battery behaviour in parallel
« Reply #1 on: July 10, 2006, 09:59:51 PM »
If you have two batteries in parallel (and most RE systems do), the batteries will see quite similar currents if they are the same type age, history, etc.
However, over time, the battery strings, being not identical due to all kinds of reality things, will diverge in their capabilities.  The time-honored way to deal with this is to "equalize" the batteries from time to time, which means to charge up the batteries until they start gassing. Since they are no longer accepting a charge when they are gassing, all battery strings will eventually become much more equal in their state of charge (some will stop accepting charge sooner than others, but eventually, all will).
I recommend to use Hydrocaps (a device that replaces your regular battery caps and will recombine the H2 and O2 gas into water so you don't have to add water so often), to use a battery desulfator (try www.homepower.com for a circuit or google it to purchase one), and to equalize about every 3 months.  Of course, your mileage may vary, and you should equalize and check water often until you get a good feel for your system.
As far as how often a battery (cell) short-circuits, I have never seen it happen, but as has often been said, batteries seldom die, but are often murdered. Um, oh wait, yes, in fact, I have murdered a battery which short-circuited, by letting my truck sit for months at a time, many times, without starting it and recharging the battery (eventually, I bought a solar charger which solved the problem). You can tell that a cell has short-circuited if you charge and condition a battery and the ramp and/or gassing voltage is less then you expect by 2.2 volts (ramp) or 2.5-2.6 V (gassing).
I'd love to give you an URL which tells all about batteries, but I've found few good ones, and I can never seem to find them when I need them.
BoL,
Dave
« Last Edit: July 10, 2006, 09:59:51 PM by altosack »
Volvo farmer
« Reply #2 on: July 10, 2006, 10:10:06 PM »
Most things I've read, including the Rolls website for my batteries, recommend an equalization charge every thirty days.
Here's a good website for battery maintenance.
http://www.independent-power.com/battery_maintenance.htm
« Last Edit: July 10, 2006, 10:10:06 PM by Volvo farmer »
Less bark, more wag.
iFred
« Reply #3 on: July 10, 2006, 11:59:54 PM »
yes, equalization charge every thirty days or less. If you notice the batterys getting sluggesh to reach charge level then equalize.
« Last Edit: July 10, 2006, 11:59:54 PM by iFred »
