Author Topic: silly question about desulfation  (Read 1223 times)
isaac338
« on: July 19, 2006, 07:18:34 AM »
I've read some stuff about battery sulfation, and from what I understand one way to attempt desulfation is to charge the battery at 25A, then apply a 25A load and repeat the cycle a few times. My question, albeit probably a pretty silly one, is how do you apply a 25A load? Do you just hook up some kind of heater or something that draws 25A, or is there a load tester of sorts you can buy?
I've seen load testers at places like Harbor Freight but they're all rated at 100A.
I'm probably missing something obvious, enlighten me please :)
Thanks,
Isaac
« Last Edit: July 19, 2006, 07:18:34 AM by (unknown) »
ElSenator
Re: silly question about desulfation
« Reply #1 on: July 19, 2006, 02:37:33 AM »
Most of those are Variable load testers, I believe, and use a dial to adjust the load. Quite worth it! I like my carbon pile load tester. Quite cheap on ebay...
« Last Edit: July 19, 2006, 02:37:33 AM by ElSenator »
« Reply #2 on: July 19, 2006, 06:29:25 AM »
A few smaller loads at the same time?
A car headlight draws about 5A, and an #1156 tail light bulb draws about 2.2A.
Maybe a 400~500W inverter powering 3, 100W 120V bulbs...
« Last Edit: July 19, 2006, 06:29:25 AM by ghurd »
shmuu102
« Reply #3 on: July 19, 2006, 04:25:10 PM »
what if i have a charger that max's out at 15A?
Can i cycle these wo forklift batteries i have at 15A to bring them back to life?
(they are free, so i think im gonna try anyway.. i  will post my results.)
« Last Edit: July 19, 2006, 04:25:10 PM by shmuu102 »
