Author Topic: 24 volt retap  (Read 1805 times)
brushycreek0
24 volt retap
« on: September 15, 2006, 07:15:03 AM »
Got me a 24 volt forklift type battery.  Retapped it to 12 volts so
I can keep it charged this winter.  Bought a set of sacrifcial
jumper cables (4/0 wire size) cut to lenth and crimped on ends with coaxial
cable crimps.  Used hole saw with drill bit removed to detach
lead bars.  Use vacuum cleaner to keep lead shavings from getting inside
battery.
big pic 1
big pic 2
big pic 3
big pic 4
big pic 5
i made your pics links becouse they are to large please keep your pics under 100k
Kurt
« Last Edit: September 15, 2006, 07:15:03 AM by (unknown) »
DanB
    • otherpower.com
Re: 24 volt retap
« Reply #1 on: September 15, 2006, 08:45:44 AM »
Yes, I dealt with mine exactly the same way.  Curious - where did you  get that?  Theres a guy on ebay with a few 24V batteries and Im interested... if they are any good.  He's not been responsive to email though...
I've got a huge 72V forklift battery that I tapped (exactly like you did) @48, and I have a useless 24V there sitting at the end.  I need another 24V set to run in series with that so I can double my current capacity - so if you have any leads for a 'bargain' on something that would be suitable I'd be very interested!
« Last Edit: September 15, 2006, 08:45:44 AM by DanB »
Shadow
Re: 24 volt retap
« Reply #2 on: September 15, 2006, 02:42:47 PM »
Hey Dan, Heres a link that may be a lead to some batteries. Not sure where they are though.http://www.outbackpower.com/forum/profile.php?mode=viewprofile&u=312
« Last Edit: September 15, 2006, 02:42:47 PM by Shadow »
Re: 24 volt retap
« Reply #3 on: September 15, 2006, 02:43:51 PM »
Why the extra taps at 8V?
« Last Edit: September 15, 2006, 02:43:51 PM by Ungrounded Lightning Rod »
Shadow
Re: 24 volt retap
« Reply #4 on: September 15, 2006, 02:44:21 PM »
oops, clik on the batterys, batterys batterys topic up top.
« Last Edit: September 15, 2006, 02:44:21 PM by Shadow »
brushycreek0
Re: 24 volt retap
« Reply #5 on: September 16, 2006, 06:30:24 AM »
Messed up cut the wrong lead bars. This battery has been a good education, each cell is 2.2volts.
« Last Edit: September 16, 2006, 06:30:24 AM by brushycreek0 »
brushycreek0
Re: 24 volt retap
« Reply #6 on: September 16, 2006, 08:05:58 AM »
Hi Dan, I received the battery from my Dad that he got
from a local industery where he's retired from.  Hope
to get another 24v or a 48v when one becomes availible.
Just for information perposes I hooked a car charger
24 hours ago.  Its about half charged now.  A couple
more days of charging it will be ready for winter.
One of the cell is weak.  I'm going to put together a
watgas desulferator circuit and maybe jerk it back to
life.
« Last Edit: September 16, 2006, 08:05:58 AM by brushycreek0 »
