Author Topic: nife batteries  (Read 5003 times)
learning 2
nife batteries
« on: May 23, 2008, 01:12:27 AM »
Can anyone tell me where in Australia I can buy nickel iron batteries? Even second hand ones.
« Last Edit: May 23, 2008, 01:12:27 AM by (unknown) »
wpowokal
Re: nife batteries
« Reply #1 on: May 22, 2008, 08:06:40 PM »
I suspect this company, check out the cost of disposal of these batteries before buying, and I am told they are about 4 times the price of lead acid.
Saft Batteries
Unit 18/167 Prospect Hwy
Seven Hills 2147
New South Wales
Australia
 Postal Address:
P O Box 883
Seven Hills 1730
New South Wales
Australia
Phone:  61 2 9674 0700
Fax:  61 2 9620 9990
 allan down under
« Last Edit: May 22, 2008, 08:06:40 PM by wpowokal »
independent
Re: nife batteries
« Reply #2 on: May 22, 2008, 10:26:09 PM »
There is a Changhong battery distributor in Oz. Their factory is in Sichuan province where the recent devastating earthquake was centered. However, I have been assured their factory is fine (and no one in their workplace has been hurt). There are only a few NiFe battery manufacturers left so I will be interested to know how you get on in your pursuit.
Out of curiosity, what size are you after and what voltage sets are you making? The batteries are made to order and are generally shipped dry. They are incredibly heavy and expensive.
I have two new sets arriving next week :-) I will be selling at least one of the sets but seeing as you are in Oz (and I'm in NZ) and there is a distributor where you are I would suggest buying them in your locale
I learned alot about NiFe batteries from this board. There is also plenty of info on Homepower magazine. However their articles are no longer free, but text files can be seen (downloaded) from ibiblio.org
There is a manufacturer of Nicad batteries called, "Nife". I am writing this on the assumption that you mean the Nickel Iron -type of battery and not Nicad manufacturer.
« Last Edit: May 22, 2008, 10:26:09 PM by independent »
independent
Re: nife batteries
« Reply #3 on: May 22, 2008, 10:34:05 PM »
Ahh, I see you actually mean Nickel Iron.
The other thing is they are not expensive to dispose of, in fact you will get money from them. Nickel is a highly sought after metal and worth alot and the chemistry is relatively non-toxic. Part of the reason these batteries are so expensive is the cost of the raw material. Out of all of the battery types Nickel Iron are the least toxic and also should (all things being equal) last the longest.
Nicad batteries however are a different proposition and maybe that's why the poster above is making the statement about difficulty of disposal.
« Last Edit: May 22, 2008, 10:34:05 PM by independent »
snowcrow
Re: nife batteries
« Reply #4 on: May 23, 2008, 07:27:46 AM »
  Just my opinion but, a Ni-Fe battery's  lifespan is all it has going for it!!  They are only about 65% Charge/discharge efficiency, with a 20% to 40% Self-discharge rate/month!!!
http://en.wikipedia.org/wiki/Nickel-iron_battery
  If you're going to spend 4 time the cost of Lead acid batteries, might want to look at Lithium-ion batteries.  They store more than twice the Energy/size (Wh/l) than Ni-Fe batteries and have a 99.9%  Charge/discharge efficiency. They also cost 1/3 less.
http://en.wikipedia.org/wiki/Li-ion_battery
Blessings, Snow Crow
« Last Edit: May 23, 2008, 07:27:46 AM by snowcrow »
independent
Re: nife batteries
« Reply #5 on: May 23, 2008, 01:14:02 PM »
I've seen efficiency ratings from 70-80% for Ni-Fe from good sources (I have a trimetric 2020 meter and I plan to test for this). What I find interesting in relation to efficiency and hope to find out properly is that the 20 hour rate for a 100Ah is, ummm 100Ah, but the 100 hour rate is 122Ah. So, something is a bit strange in relation to efficiency. So, far my best guess is that the thing about these batteries is not so much the efficiency but the giving up of electrons, or discharge rate. They really don't like big amounts of current being pulled out of them at any one time and this is what these batteries need to be sized for.
Speaking of efficiency:
Sealed Pb-A at 95% and wet cell Pb-A are around 90%. There are differing opinions but sealed Pb-A have a cycle life of between 200-500 (higher from specialty manufacturers) at reasonable DOD. Wet cell varies greatly, from 500-1300ish (again, higher from specialty manufacturers) from what I can gather. These are at %50 or less.
Li Ion batteries that are commonly in use in cellphones and laptops (generally referred to as Lipo, or Lithium polymer), are only rated for 500 cycles max, require very careful balancing and charging voltages and prone to failure through runaway (uncontrolled) chemical reactions (fire!). Obviously these aren't to be used in RE systems and I'm only mentioning it here to avoid confusion as that's what most people think when they think Li Ion.
However, of the technologies mentioned in the wiki article, the technology that's here--now--are LiFePo4 (Lithium Iron Phosphate) batteries. These are are different story. Cells based on this technology have a cycle life at least 1000-2000 and more at lower depths of discharge. However, this technology is new and the various manufacturers of this tech have varying degrees of quality. From what I can gather so far the best manufacturer of this tech at the moment is a123 systems, a US based company made up of graduates from MIT. There are other specialist manufacturers of this type of battery, LionEv makes 100Ah and 200Ah cells and they cost (at the time of writing) $US302.95 and $US519.95 respectively per cell (complete with balancer and wiring gear); each cell is rated at 3.2v, so you'll need 4 for a 12v system. Obviously, this is doable, and are ripe for using in RE systems. There are also some of this type of cell being hand-made to order (duct tape batteries on ebay) and going into electric bikes. They are cells made in China and look interesting. In my opinion the people who are doing the most interesting investigating on new (and old) battery technologies are the EV (electric vehicle) guys (and they do seem to be guys doing it). With this community there is plenty of testing and sharing of information on the web.
There are also super-capacitors with nano tech and these are promising for storage. But we are talking about what's available 'now'--right? Personally, I'd hate to see what happens to a super, or ultra cap if a fissure happens in the dielectric layer. I suppose we'll soon find out as the new Honda FCX uses these for temporary storage for power from it's fuel cell.
I've been researching battery technology for the last 9 months for use in RE systems. It just seemed like the weakest link in RE and worth looking into. In my mind, the best system would be no batteries at all, a kind of Internet-of-Power generation where people could generate electricity like people generate data. I suppose we kind-of have this already, the main thing hampering it are the power generation companies and legislation (in most parts of the world). As they say, the devil is in the details, and with grid tie that is definitely true. So, we are left with storing our own electricity chemically. NiFe seems as good, if not better, than most solutions out there to me. It's the only battery people talk of handing down to their children (or grandchildren) so I'm willing to give them a go.
« Last Edit: May 23, 2008, 01:14:02 PM by independent »
Re: nife batteries
« Reply #6 on: May 23, 2008, 02:12:31 PM »
The newer lithium iron phosphate batteries don't crash and burn like the lithium cobalt batteries do.
They're not cheap, though. http://en.wikipedia.org/wiki/Lithium_iron_phosphate_battery
If I could afford them, I would get those or NiMH batteries for my electric bike. 4 agm sla's weigh almost as much as the bicycle.  http://www.walmart.com/catalog/product.do?product_id=8467094
I need two packs to make it to work (12 miles) without pedaling.
« Last Edit: May 23, 2008, 02:12:31 PM by dnix71 »
