Author Topic: Copper interconnect straps  (Read 22398 times)
Boss
  • http://outfitnm.com
Re: Copper interconnect straps
« Reply #33 on: April 21, 2010, 10:48:43 AM »
ULR wrote
(Remember that "N-hop-long" means N times the wire length as a short jumper,
even if that means more slop lying about.)
Am i nit picking when I wonder if the cable length of "N" includes the lugs, or will I measure from lug hole to lug hole and make this length "N"? In other words would it be okay to measure from crimp to crimp
Brian Rodgers
DanG
« Reply #34 on: April 21, 2010, 01:29:55 PM »
Once you get down to the millimeter you've done precision work, the only constant you can control is the length of wire.
Even if you duplicate each crimp sequence you're not going to keep the assembly from varying in length somewhat.
Boss
« Reply #35 on: April 21, 2010, 02:34:27 PM »
This is how I interpret the wiring. I've left out the series connections for simplicity
Starting from the daisy-chained version:
 - Unhook both jumpers between batteries 2 and 3, and between 4 and 5.  (Discard or save for spares.)
 - Hook a new 4-hop-long jumper between + on battery 2 and + on battery 6.
 - Hook a new 4-hop-long jumper between - on battery 1 and - on battery 5.
 - Hook a new 2-hop-long jumper between + on battery 2 and + on battery 4.
 - Hook a new 2-hop-long jumper between - on battery 3 and - on battery 5.
 - Hook up the feeds to + on battery 2, - on battery 5.
Only problem I see when I am measuring this out is that where"N" equals one of the original lengths, it isn't long enough to reach
I could add ~ an inch, but it would be tight
How important are the actual cable lengths? I see that Dan G says a milimeter  is precise, how's this inch extra going to effect connectivity?
Brian Rodgers
Boss
« Reply #36 on: April 21, 2010, 08:13:34 PM »
Alrighty then, the battery interconnects are sorted, thank you to everyone for your help
I had to mod two bolts to fit the connections where four lugs connect, after I realised there was going to be five cables, plus the #10 diversion load controller leads, I made one more interconnect for those and tied them into the main connector
From this angle you can see the receptacle for the three cables leading from the tower making a easy to deal with disconnect for the tower in case I need to untangle the cable
Here is the insulated battery box with its cover on.
Above the 2500 watt MSW inverter is doing a great job powering out 35 inch CRT TV, home theater amp, DVD and our favorite new device the Roku Internet streaming video router. Above right is the three blade kill switch for the turbine, rectifiers on an recycled amp heat sink
Brian Rodgers
Peter-
« Reply #37 on: April 22, 2010, 02:12:56 PM »
ULR wrote
Boss -- I *always* measure from lug hole to lug hole. Like center to center. Because think about it like this: It's a lot easier to cut out some extra, than it is to add some back in. This way you got some slack to work with. With really big DC power like this, it's better to have a few inches extra on the cable instead of having to splice it. The losses are lower. Kinda like wood-working and metal-working: measure twice, cut once.
When I worked as a welder, it added up at the end of the month: a hundred-foot cable with a splice cost more to use and it showed up in the company's power bill, even though it was just a tenth of an ohm.
« Reply #38 on: April 22, 2010, 02:42:22 PM »
I am not disputing you believe it.
Not sure I believe it.
Welding with 120A, 8 hours a day, 40 hours a week, 4 weeks a month, is about $25, maybe $50?
Moving assemblies/parts/cables/items/etc, fitting parts, rearranging, etc., be pretty lucky if an electrode was struck 1 hour a day?  $3 to $6 a month.  The bulb in the Coke machine uses more than that.  The new guy they hired, a slacker, who spends half the day making fresh coffee, uses more than that, but he got hired and fired while you were using the spliced cables?
Or, a sustained 1440W power dissipation in 1~2" of cable is going to cause some issues before the electric bill arrives.
Peter-
« Reply #39 on: April 22, 2010, 03:55:43 PM »
[/quote]
Actually Ghurd it did happen just like that. Myself and my guys were striking an arc much more than that, (every few seconds) and the company was particularly cheap: they watched every penny literally. To be fair, it was privately owned and not traded, and electric rates are fairly high here in upstate NY. I had to educate the big bosses about how to do things since welding was only a very small part of their business -- it was not the main thing. Even though I was the "leading man" in that dept.
We used anywhere from 120 to 500 amps of DC for at least 8 hours a day, 6 days a week. The building was fed with 600 VAC 3-phase and the welders used 480-volts 3-phase. It was difficult because be had to carry this current over a long distance, being a construction company basically.
If things were busy in the summer, then it added up fast and the big bosses would figure that into the bill. They had an 150-foot 3-phase 4-wire extension cord on a spool, and you had to drag that out to the site along with a few hundred pounds of welder machine.
I told them to get diesel generator-welders, but they never did. It was all about the up-front costs.
« Reply #40 on: April 22, 2010, 04:13:12 PM »
Exactly what I meant.
Peter-
« Reply #41 on: April 22, 2010, 05:20:08 PM »
I will shut up leave now then. But IMHO every little bit counts when you get into triple-digits DC amperes and long runs.
