Author Topic: Fridge to heat pump?  (Read 1817 times)
jaybee
« on: August 24, 2005, 09:26:20 PM »
Am I right in thinking that a heat pump is just a fridge in reverse as it were?
Could I not run my coil tube buried outside through an old fridge and take the heat generated?
« Last Edit: August 24, 2005, 09:26:20 PM by (unknown) »
benjamindees
Re: Fridge to heat pump?
« Reply #1 on: August 24, 2005, 03:35:01 PM »
Perhaps a freezer would be better.  You want to be able to make the coils colder than the outside temperature.  This is the reason heat pumps aren't used in really cold climates.
« Last Edit: August 24, 2005, 03:35:01 PM by benjamindees »
