Author Topic: Low Starting Torque, Low Friction Alternator!  (Read 2919 times)
mechamz
« on: September 19, 2008, 07:20:06 AM »
Hi, I'm currently doing a VAWT prototype.
I'm happened to find these 2 alternators, but not sure which is better?
http://www.ginlong.com/wind-turbine-pmg-pma-permanent-magnet-generator-alternator-GL-PMG-500A.htm
http://www.windbluepower.com/DC_540_Low_Wind_Permanent_Magnet_Alternator_p/dc-540.htm
the dimension of the Savonius turbine, height is 0.8m and width is 0.43m
My system require a low starting torque and low friction alternator. Previously, I've purchased one from http://energistar.com, but the performance was far from the information given.
I hope the alternator able to generate 12V and more than 1 or 2Ampere at low rpm, and low torque required. Any better suggestion than these 2 alternators are welcomed.
or something like this, http://www.gotwind.org/diy/Axial_Flux_Alternator.htm
Any idea??
« Last Edit: September 19, 2008, 07:20:06 AM by (unknown) »
Re: Low Starting Torque, Low Friction Alternator!
« Reply #1 on: September 19, 2008, 07:25:10 AM »
hello mechams,
your savonius is .43x.8=.34 sq.m.swept area.
because of the design it is actually harvesting energy from only 1/2 that.
so .17sq.m.
you are trying to capture a percentage of the winds energy
contained in a space the size of a piece or writing paper.
(32%(savonius) of 60%(betz limit) of the actual wind energy)
there is no magic involved.
the  alternators you have suggested are much to large for the devise you have built.
« Last Edit: September 19, 2008, 07:25:10 AM by electrondady1 »
