Author Topic: Radiator Fan Blade?  (Read 941 times)
Opera House
Radiator Fan Blade?
« on: June 24, 2004, 07:42:34 PM »
Finally found the multi blade fan from the Ford Explorer that I had stashed away years ago. Will mate that with a small 40V servo motor with the hope of getting about 1A @12V out of it.  Looks like if I mount the blades backwards it has a decent profile.  Everything is free so it is worth a try.  Just have to turn down a shaft bushing to mount it on.
« Last Edit: June 24, 2004, 07:42:34 PM by (unknown) »
wpowokal
Re: Radiator Fan Blade?
« Reply #1 on: June 25, 2004, 06:12:06 AM »
Yes I used a 7 blade fan from a Chrysler V8 I added extensions of aproximatly 8" to each blade, all worked fine on a TDM.
I then removed the blades and replaced them with 500mm long 2" wide PVC intended as cover strips for fibro cement sheets, also works fine to this day.
regards Allan
« Last Edit: June 25, 2004, 06:12:06 AM by wpowokal »
« Reply #2 on: June 25, 2004, 08:25:00 AM »
If money is a problem then you qught to consider making blades from PVC pipe.
Here are some plans...
http://66.140.203.100/gallery/album38
« Last Edit: June 25, 2004, 08:25:00 AM by wooferhound »
Opera House
Hope I don't have to extend them
« Reply #3 on: June 26, 2004, 01:39:11 PM »
Although it is only 18 inches, it has 10 blades and is so cute.  My manager once told me, "The optics of a project is everything."  I have five days to whip this together before I go to the camp.  Prefer to have five small ones rather than one big one.
« Last Edit: June 26, 2004, 01:39:11 PM by Opera House »
sean
« Reply #4 on: June 27, 2004, 05:13:34 PM »
All i have ever made props from (HAWT) is fans from cars. There cheap and work very well so i found although i must point out that i have never carved a prop from wood so i cannot comment on comparison. See the wind links on my site. http://homepage.ntlworld.com/s.amesbury/homepage.htm
...Sean
« Last Edit: June 27, 2004, 05:13:34 PM by sean »
