Author Topic: stator problem  (Read 993 times)
paulh
stator problem
« on: June 29, 2004, 04:39:37 AM »
I cast a 6 coil stator to go with a pair of 12" 8 magnet rotors, but on opening the mould I have found that the coils have moved so the spacing between them is far from even.Now the question is do I use this as it is or make a new one? I think it should work but I need some advice please!
thanks,
Paul
« Last Edit: June 29, 2004, 04:39:37 AM by (unknown) »
Re: stator problem
« Reply #1 on: June 29, 2004, 06:31:58 AM »
A picture or drawing would be helpful.
Not sure if your 6 coil, 8 magnets design is correct eather.
« Last Edit: June 29, 2004, 06:31:58 AM by wooferhound »
paulh
Re: stator problem
« Reply #2 on: June 29, 2004, 08:35:33 AM »
I think the 6 coil 8 magnets per rotor should work as I am using Hugh Piggotts PMG plans http://homepages.enterprise.net/hugh0piggott/pmgbooklet/itpmg.pdf.I'll try and work out how to post a sketch next!
Paul
« Last Edit: June 29, 2004, 08:35:33 AM by paulh »
