Author Topic: blade tracking  (Read 759 times)
dconn
blade tracking
« on: July 25, 2004, 11:53:21 AM »
I have read (Hugh Piggot's books) that it is important that the blade tips track each other through the same space.  I have a set of 3 blades where one blade tip is slightly forward compared to the other two blades.  Do you think this is a real problem?  will it cause a great deal of vibration?
Thanks everybody,
Derek
« Last Edit: July 25, 2004, 11:53:21 AM by (unknown) »
Re: blade tracking
« Reply #1 on: July 25, 2004, 12:30:19 PM »
Depends how far it's out, the speed of the blade , diameter and relative weight of the tips amongst other things.
If it is more than 1/2 inch out on an 8 ft prop I should be rather bothered.
If it is made in the usual way with a plywood disc at the back I would plane or sand the disc at the right point to tip that blade in line.
Bad tracking introduces dynamic un-balance that you can't correct without a balancing machine and also if bad enough will cause aerodynamic problems that you can't correct at all.  If it is only slightly out it may be ok.
« Last Edit: July 25, 2004, 12:30:19 PM by Flux »
dconn
Re: blade tracking
« Reply #2 on: July 26, 2004, 06:52:47 AM »
Thanks very much Flux,
I kinda thought that the answer would be along the lines of your reply....
Derek
« Last Edit: July 26, 2004, 06:52:47 AM by dconn »
