Author Topic: 7 ft wood blade upgrade.  (Read 908 times)
« on: October 01, 2004, 08:47:41 PM »
2 years ago I had a carpenter freind build a 7ft 3 blade wood prop.
It looks good but doesn't work very well. I think its just too flat  from root to tip.
I don't think being flat at the tip is hurting anything but it needs more pitch at the root.
I'm thinking of adding aluminum flairs or skirts at the root and extend them about 1/3 rd the way towards the tip. I'll use bolts through the blade. This will hold the aluminum to the blade. The leading edge pice will be on the front (wind side) and the trailing edge pice will be on the back.
It boils down to this or use it for fire wood. I thought I'd give it one more chance and I have a nice pile of scrap aluminum any way.
I don't think the aluminum will be stressed in this hybrid blade the way it would be stressed in an all aluminum blade?
I'll try to get some pix. Any thoughts or maybe sugjest a good shrink?
« Last Edit: October 01, 2004, 08:47:41 PM by (unknown) »
Re: 7 ft wood blade upgrade.
« Reply #1 on: October 01, 2004, 08:51:07 PM »
PS the aluninum will be bent to creat a steep pitch at the root.
« Last Edit: October 01, 2004, 08:51:07 PM by Jerry »
zubbly
« Reply #2 on: October 02, 2004, 09:17:36 AM »
Hi Jerry!
only way is to try it and find out. I do this often. most of the time it works out to my thoughts and reasoning, sometimes it does not.
But the greatest fun and best way to learn is in the doing!
have fun
zubbly
« Last Edit: October 02, 2004, 09:17:36 AM by zubbly »
« Reply #3 on: October 02, 2004, 09:37:03 PM »
Heres a picture of the blade if it works?
Its just resting on that stump?   JK TAS Jerry
« Last Edit: October 02, 2004, 09:37:03 PM by Jerry »
