Author Topic: Woden hub pix?  (Read 1487 times)
Woden hub pix?
« on: October 04, 2004, 10:30:07 PM »
These will work for plastic pipe blades when doing 3 or 4 blades.
« Last Edit: October 04, 2004, 10:30:07 PM by (unknown) »
domwild
Re: Woden hub pix?
« Reply #1 on: October 04, 2004, 11:50:07 PM »
Jerry,
Great pictures! Don't you get sick of building ever more gennies? Keep up the good work! Tell me when the 20th genny is flying!
Tell me: What do Americans mean by a #10 bolt? Pls send us the thread dia. in inches as us Aussies do use the metric system and the only imperial measuring unit we still like is the pint!
Dominic
« Last Edit: October 04, 2004, 11:50:07 PM by domwild »
cevonk
Re: Woden hub pix?
« Reply #2 on: October 05, 2004, 01:53:36 AM »
Simply elegant!  Very nice!
« Last Edit: October 05, 2004, 01:53:36 AM by cevonk »
MelTx
Re: Woden hub pix?
« Reply #3 on: October 05, 2004, 04:55:11 AM »
   Domwild et al.  A number 10 bolt is small the outside dia. is .194 it has 24 threads per inch. A 3/16 ths" is .187" so its close to that.I tried to load a chart that has the bolt sizes, hope it loads. Maybe this will help
« Last Edit: October 05, 2004, 04:55:11 AM by MelTx »
Re: Woden hub pix?
« Reply #4 on: October 05, 2004, 07:20:02 AM »
   Would a cross-section from the thickest part
of a bowling pin work? (if you had one...that is?)
                  Norm ( :>)
« Last Edit: October 05, 2004, 07:20:02 AM by Norm »
hvirtane
    • About Solar Cooking
Re: Woden hub pix?
« Reply #5 on: October 05, 2004, 12:16:38 PM »
It looks really nice.
Did you try to do
something similar with
'Jerry blades'?
« Last Edit: October 05, 2004, 12:16:38 PM by hvirtane »
Harry Luubovv
Re: Woden hub pix?
« Reply #6 on: October 05, 2004, 02:48:07 PM »
A " #10 " bolt is a bolt slightly smaller than a quarter of an inch dia. bolt. But they do come in both 24 and also 32 threads, one is "Course thread" and one is "Fine thread".
Thanks,
good day to you mates,
Harry.
« Last Edit: October 05, 2004, 02:48:07 PM by Harry Luubovv »
Re: Woden hub pix?
« Reply #7 on: October 05, 2004, 09:14:42 PM »
Hi Hannu
I've done the round 4 blade wood hub with Jerry blades. I do these wood hubs without the aluminum supports.
The slot supports such a broad part of the blade that if gives addaquite support.
When doing the wood hubs the 2X2" mounting tab is cut off.
« Last Edit: October 05, 2004, 09:14:42 PM by Jerry »
