Do you mean that I should keep the yaw bearing as close to the front of the machine as possible?
No. Your yaw bearing should be under the center of gravity.
What I mean is: Your yaw bearing is of non-zero height. Think of it as actually being two bearings - one higher and one lower on the pole:
- The weight appears as a downward force on one of them or distributed between them.
- The wind drag appears as a sideward force - centered at the height of the shaft of the prop. If that's at the height of the top bearing, it appears as a sideward force on that bearing, if below it's split between the two, if above it appears magnified on the top bearing and with a reverse sideward force on the bottom.
- The gyroscopic torque from yawing the spinning prop appears as a sideward force on the top bearing and an equal sideward force in the opposite side of the bottom bearing.
The top "thought bearing" represents the top of the actual bearing and the bottom one represents the bottom of it. This would be for something like a pipe-over-pipe bearing. (Alternatively, if your bearing is really thin, a torque on the genny assembly (along a horizontal axis, not along the pole's vertical axis) appears as an upward force on one side of the bearing and a downward force on the opposite side.)
The spacing of the "thought bearings" composing the top and bottom of the actual bearing doesn't matter for downward weight, sideward drag, or yaw's twisting around the vertical axis. But for torque along a horizontal axis - from gyroscopic reaction, off-center wieght, or off-center drag - it's the short arm of a lever.
The longer the bearing, the longer the short end of the lever. The longer the short end, the lower the sideward forces on the ends of the bearing for a given torque. The less side-force, the less friction. The less friction, the less restriction of yaw and the less wear on the bearing.
So if you expect a lot of gyroscopic torque, you want your bearing to be long. If it's pipe-over-pipe you'd be better with a foot than with inches of overlap. If it's some sort of physical bearing, you might want to think about adding a second one (dealing with side-forces only) a bit further down. (The second one needen't be as fancy as the top one, since it only deals with side-force from torque and some friction is fine.)
