I always used to think there were. 'Dumb questions', but after following this site for awhile, no-one ever sees any question as a'dumb question' and all are answered accordingly.
It has been said that the only "dumb question" is the one you didn't ask. B-)
There ARE "ignorant questions". But reducing ignorance is the whole POINT of asking and answering questions, isn't it? If it's not an "ignorant question" why was it asked?
Everybody starts out ignorant and has to learn to become informed. Questions are the most focused way to spread information from those who have it to those who don't.
Why was 110/120volt decided on to be the standard?.. Why not 80 volt?..or 100 volt?
I think the standard voltage was picked by Edison for his urban DC system. The higher the better for minimizing the amount of copper you need to ship the power and/or maximizing the distance you can ship it. But if you go too high you get arc-over on the DC generator's commutator.
Tesla got to pick the stepped-up transmission voltages and the frequencies. But I think the delivery voltage was picked to have the same power delivery into resistive loads (incandescent lights, resistive heating appliance) and so "universal motors" (wound rotor, wound field, laminated cores throughout) could be built that would work equally well on either. This let Westinghouse avoid building separate lamps, toasters, and hotplates for his customers and requiring them to convert if they wanted to hook up to his system.
110/115/120 volts was convenient for a number of reasons, besides being a good tradeoff for city-block-scale transport. It's low enough that - AC or DC - it won't automatically kill you if you touch it (though it will if you grab on and may if your skin is wet), jump across even pretty small gaps, or start a persistent arc through a water drop (though it will leak through moist materials or touch it with a metal tool). It's high enough that house wiring is affordable and doesn't waste a lot of power in heating itself. Tube-type radios could rectify it directly and use the resulting voltage for signal processing power without the cost of a voltage-conversion transformer. (Indeed, the "all-american five" five-tube design could run on AC or DC, provided you plugged it in the right way on DC.)
