Oil sucks, wind blows.
Carpe Vigor
Dr.D
A slide From north to south will creat a Zero point with voltage above and below depending on the direction of the coil winding of coarse . The Brushes connect the different coils on the armature that is wound in the same direction so you'll see a alternating current as they pass through the the field magnet north south etc. Put a diode in there and a cap youll see what the no load will be.
