Hi Flux/Shadow...
yes, this is quite strange and surprising. I've made 48 volt machines with this same scheme(same number of windings, same coils and same wire gage), but
much larger (2" dia X 1/2" disk) magnets and too low of cutin speed (110 rpm) and they didn't stall this badly. (they did stall, but not any worse than this) So it makes no sense that this thing has trouble getting over 160 rpm. Ill insert some comments/information into Flux's posting here.
"Yes that does seem to have all the characteristics of severe stalling. I am not sure if Dan has done a 48v version of the 10ft, the high voltage alternators are always more efficient and more likely to stall."
Yes, I've seen that. Lately its been my thinking to use slightly larger magnets on the 12 V machines (Because they seem to overspeed a touch when we use these 1" X 2" X 1/2" blocks) - the 12V ones work very nicely with slightly larger magnets. I wouldnt expect a 48 volts stator to stall this obnoxiously with the smaller blocks though.
"Let's see what the heater does, I think you are looking at doubling the prop speed in a 30 mph wind."
yes... that'd be interesting (Id be careful though and be prepared to shut it down quickly if it starts overspeeding so close to the ground... that can get dangerous if your in close proximity).
"I can't find any figures for Dan's 10ft blades, can you remember the widths and drops at the various radii? I really am puzzled by this one. Hugh's 8 ft prop ought to be able to drive that alternator without stalling and I didn't think that Dan's was that much different, Dan's alternators are very similar to yours."
The blades I've been making lately are very simple - its very simplified so that we can carve them quickly with a planer. They seem to do pretty nicely on machines up here, starting up very easily and producing around 100 watts or so in fairly low winds. In higher winds we frequently see upwards of 1.5KW from them.
They are made from 2 X 8 boards basicly (but ours are laminated). The tips are 3" wide, at half the radius we're 5" wide and its a straight taper to full board width (7' 6"). At the tip they are pitched 3 deg, at half the radius (where we are 6" wide) they are pitched 6 deg, and the front of the blade is a totally 'flat' plane (this side we do on a planer completely). The thickest part of the airfoil is 1/3 of the way back from the leading edge, and the thickest part of the blade is always 1/8 as thick as it is wide. (so were 3/8" thick at the tip, and 3/4" thick at half the radius). It's a very simple arrangement.
"How thick is your stator?. From your cut in speed I suspect it is between 1/2" and 5/8"."
Judging from the wire he used and his cutin speed, I expect the total airgap must be about 5/8" - 3/4", his stator I believe is 1/2".
"Can you get at the coil leads to change it to delta if the need arises?"
I dont think he'd want to do that, even if he could. It would bring his cutin speed way too high. As it is now, his cutin speed is, if anything, a touch on the high side for a 10' prop but within reason I think.
I would be curious to know how high it is off the ground, and if there are any serious obstructions in front, or behind it. I'd be curious if there was anything odd about the blades too. It really seems unlikely that it should stall this badly with a 10' blade on it - and those windings, and those magnets.
I'll be very curious to know what solves this one!
