Author Topic: Stronger Magnet Better for Hugh's 10 Coil Stator?  (Read 910 times)
JerryD
« on: March 21, 2005, 03:43:56 AM »
Just wondering if stronger magnets are better
or should I stay  exactly with Hugh's plan?
Which by the way is 10 coils 80 trns #15
What would happen if I used the stronger wedge
shape magnet ?
Also Just finished my stator and the casting is about
11/16 thick, how much will this affect the
performance ?
Thanks; JerryD
« Last Edit: March 21, 2005, 03:43:56 AM by (unknown) »
Re: Stronger Magnet
« Reply #1 on: March 21, 2005, 03:04:00 AM »
To gain from the bigger magnets you will have to change everything, it's a complete re design.
To use without modification you will have to space the rotors much more to keep the flux the same. This may need more spacers than is really desirable. It will cost a lot more to get the same result.
« Last Edit: March 21, 2005, 03:04:00 AM by Flux »
DanB
    • otherpower.com
Re: Stronger Magnet Better for Hugh's 10 Coil Stat
« Reply #2 on: March 21, 2005, 05:48:02 AM »
Hi Jerry - larger magnets in this machine will lower the cutin speed, which you probably dont want.
Well have 1" x 2" blocks back in stock next week I think.
The 11/16" stator wont hurt you too much...
« Last Edit: March 21, 2005, 05:48:02 AM by DanB »
