it makes 5 phase power, with a ton of wasted magnet power. the coils will need to have the traditional magnet-sized hole in them, but they will be spaced far apart. as weak as the ceramics are, you should definately re-consider, and wind them as a more traditional 3 phase (12 coils). in this pic:
notice how the first coil is directly under a mag, but the second mag is doing nothing thru a coil. and dont even think about making that first coil larger to grab part of the next mag, cause then your mags are fighting.
now, all of that said, if you had a cogging problem, (say cause of iron inside your stator coils) you could probably rig up some number of coils such that this was like 'skewing', but likely not with an odd number of phases.
allan
