If you really want good results in low wind and are prepared to furl very early you can use your 8ft prop if it has a tsr of about 7.
If you are stuck with the #15 wire you should be able to use about 120 turns per coil, 9 coil delta connected. There should be room .
About 70 turns of #14 connected star would be a better winding for best results in low wind.
You could use those magnets on about 11" disc with a stator about 5/8" thick.
Don't use the single phase 12 coil arrangement, you will not hold an 8ft prop down with those magnets.
