Author Topic: water proofing  (Read 1609 times)
kenputer
water proofing
« on: July 02, 2005, 02:30:16 PM »
 I have some ametek motors that I'll be makeing wind gennies with and wanted to keep the rain out of them. Would a plastic coating like the kind you can use to cover wrenches with be a good choice,i believe it is called plastic dip or is there a better way. Thanks
Kenputer
« Last Edit: July 02, 2005, 02:30:16 PM by (unknown) »
Re: water proofing
« Reply #1 on: July 02, 2005, 08:50:18 AM »
Silver muffler tape?
« Last Edit: July 02, 2005, 08:50:18 AM by ghurd »
RP
Re: water proofing
« Reply #2 on: July 02, 2005, 08:50:49 AM »
For my savonius based on an ametek I found that it slipped nicely into schedule 20 PVC drain pipe (4" I believe).  Carry it into your local hardware store and see what fits.
I used a combination of schedule 20 and 40 fittings to encapsulate the whole thing with a threaded clean-out cap on the bottom.  It allows the motor to slide out for service and I hold it to the mast with 2 large muffler clamps over the plastic.  Its been up there for about 3 years so far.
« Last Edit: July 02, 2005, 08:50:49 AM by RP »
veewee77
Re: water proofing
« Reply #3 on: July 02, 2005, 10:30:57 AM »
whatever you do decise to do, all you want is a rain-shed over it.  Do not seal the motor (genny) against water.  It will actually condense water in it and then it won't be able to get out again.
This is from experience of many years in the satellite industry.  Lots of that equipment came sealed but got water in it anyway.  Leave the seals out and it was never a problem again!!
Finally, some manufacturers leard that and started leaving things open. . .
There are some things that had to be sealed, but many things lasted longer unsealed, but just under a rain-shed.
Doug
« Last Edit: July 02, 2005, 10:30:57 AM by veewee77 »
georgeodjungle
Re: water proofing
« Reply #4 on: July 02, 2005, 11:11:40 AM »
and heat kills.
let-em breathe.
« Last Edit: July 02, 2005, 11:11:40 AM by georgeodjungle »
FishbonzWV
Re: water proofing
« Reply #5 on: July 03, 2005, 11:47:51 AM »
I have Hathaway motors and just shot a couple coats of paint on them. This sealed the front and rear end caps and the brush caps. Rubbed axle grease liberally around the shaft and drilled a small weep hole at the 6 o'clock position on the rear to let it breathe and/or drain any condensate.
This is photo before weep holes and rear grease.
Bonz
« Last Edit: July 03, 2005, 11:47:51 AM by FishbonzWV »
H.F.Fisher 1925-2007
