Author Topic: 48v gen update  (Read 826 times)
PRedATor
48v gen update
« on: August 22, 2005, 05:30:56 AM »
Here is what the wind generator is producing.
First some background on the build for the ones that haven't been following my project.
Its a 48 volt machine with 10' blades less 2" off each blade from a mishap.
It's a 24 magnet (50 x 36 x 10mm) 12 mags each rotor, 10 coil arrangement (5 Phase) 270 turns of 0.8mm wire.
80m run of 10mm^2 copper cable from gen to batt.
All on a 65' tower.
I have a weather station setup on my roof that tell me all I need to know about the weather (wind speed, direction, temp, pressure, rain fall and a forecast) but its not actually where the tower is so the stats could be a little off as interference from the roof might give false readings from wind.
I have seen already about 1 kW (20 amps)from the machine at wind speeds of 40 kmh as per my weatherstation.
I haven't seen the wind generator furl out of the wind yet (tail might be too heavy)
It doesn't start giving me power untill about 10 kmh which gives about 1 - 2 amps and sits at 5 amps 15 - 20 kmh.
Its pretty hard to get a good readings on wind as the weatherstation only updates every 128 seconds to save battery power.
I am pretty sure I am in a low wind area so I should maybe do another stator to get the best out of it.
cheers
rich
« Last Edit: August 22, 2005, 05:30:56 AM by (unknown) »
Re: 48v gen update
« Reply #1 on: August 22, 2005, 12:39:17 AM »
If my conversion from kph to mph are correct, that is a pretty good result and I don't think you will better it much with another stator.
To see if a slower stator would help, you could try it into 36 volts. Remember to compare watts not amps to get a true comparison.
Also in the 15 kph winds you could add a bit of resistance when on 48 volts and make sure you are clear of stall. Probably need a fair bit to make much difference at 48v, try 5 ohms for a first attempt.
If there is a lot more wind at hub height you may be able to tune it a bit, but if that is the wind you have up there you won't do much better.
Well done.
« Last Edit: August 22, 2005, 12:39:17 AM by Flux »
Experimental
Re: 48v gen update
« Reply #2 on: August 22, 2005, 01:36:15 PM »
        Sounds pretty impressive Rich,  and again -- Very nice job.. Bill H..
« Last Edit: August 22, 2005, 01:36:15 PM by Experimental »
PRedATor
Re: 48v gen update
« Reply #3 on: August 22, 2005, 07:00:27 PM »
Thanks Guys,
I will get 3 car batts and see how it performs at 36 volts (good idea flux)
cheers
« Last Edit: August 22, 2005, 07:00:27 PM by PRedATor »
